Question about ASUS Motherboard Striker II Formula
Configuration: Asus Striker II Formula Bios rev. 2402 Tagan 1100W BZ EVGA 8800 GT x 2 SLI DDR2 OCZ PC6400 Riper DUAL 2 x 1GB WD 500GB The problem is in POST message - INIT 8042. After I switch on it start to loop this command with black screen on my monitor. Than I have to wait couple of cycles and it start further operations. Next is "Warning boot fail" message and two options to choose "F1" move forward to start the system or "Del" to bios. I used to set automatic settings in bios and also my settings according to DDR manufacturer informations. It do not matter. There is still the same situation. I have changed mobo battery, clear the cmos. Something what is confusing me is that after some time of normal running it appears unstable voltage on different sensors controlled in PC PROBE II. Is anybody familiar with this problems ?? I need some suggestions to solve this problem. I appreciate any solutions. Chris
tom19511
  • 1601 Answers
SOURCE: cmos checksum error
cmos checksum errors are caused by a bad battery.
If that dont work then the board is bad from the factory.
Posted on Dec 24, 2007
  • 64 Answers
SOURCE: P5e Asus motherboard
best for the ground cable to connect to ur power input cable's ground. doesn't have to be direct it must just in some way get grounded. eg a wire that connects to ur house's wall is grounded
Posted on Jan 20, 2008
djnick989
  • 1067 Answers
SOURCE: Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Posted on Jan 21, 2008
tom19511
  • 1601 Answers
SOURCE: bios problem for A7V400-MX
Make sure that the battery contacts are good. If they are then you then are experiencing a faulty BIOS chip. try reflashing the BIOS. If this doesnt work, replace the board.
Posted on Jan 25, 2008
SOURCE: ASUS Striker II Formula Motherboard and SLI Problem
The memory you are using WONT work stable with 4 modules inserted on the motherboard.
According to the Qualified Vendors List (QVL) you are only able to run 2 modules stable.
Got the same motherboard and had the same memory modules (4x1GB) and wasn't able to get them stable as well.
By calling Asus they told me 2 modules max would be stable and 4 wouldn't.
And it was .. 2 modules was stable .. and 4 modules was BSOD's, freezes and hungs everytime! 2 modules was also endless Prime95 stable while 4 modules caused BSOD's after 30 minutes ..
Since Vista kinda needs 4gigs of RAM I bought new memory (OCZ XTC SLI 4096MB (2x2GB) PC6400 800Mhz 4-4-4-15) to solve this issue!
Posted on May 04, 2009
Freeze up system after booting
  • check the CPU fans for dust,
  • run a HDregenation program on the HDD
Nov 09, 2009 | ASUS M2N32 WS Professional nForce 590 SLI...
Can you mix 1gb and 2gb dimms in the same machine (for a total of 6gb)? I added two 2gb 1066 DDR2 dimms (''OCZ'') to a PC that already had two 1066 DDR2 1gb dimms (''Kingston''). I moved the 1gb dimms to...
Your MB is AM3 with 128MB DDR3-1333 built-in, four 1.8 Volt DDR2-1200+ depending on cpu. Have you enabled cpu 64 bit extensions? Tried slowing down your memory bus?
My ASUS use dual channel for dual core cpu. I have 2 yellow and 2 black dimm sockets. Both dimms in yellow is single channel, one in yellow and one in black is dual channel. Might try 2,1,2,1 rather than 2,2,1,1 order. If only your 2 1GB dimms are seen then why do you get 4 GB from 1GB+1GB? Sounds like sockets 1,2 are giving you 4GB and 3,4 don't work? Are the 1GB+1GB in 3,4 visible if the dimms in 1,2 are removed? Per Gigabyte page your AMD Phenom II 920 is AM2+ : "Note: Due to AMD AM2+ CPU limitation, memory module DDR2 1066 or above speed is only supported by 1 dimm per channel." Per AMD (which does not show your cpu, AM3 cpu fit AM3 or AM2+ socket and support ddr2 and ddr3, AM2+ cpu only work in AM2+ socket and support ddr2 only.
Oct 16, 2009 | Computers & Internet
The Dominators are high performance memory. They are spec'd for 2.1 volts, so you must set the DRAM voltage in your BIOS to 2.1 volts, not the standard 1.8 JEDEC specification. Also, make sure you set your latency timings to the following:
5=CAS Latency=TCL
5=RAS# to CAS# Delay=tRCD
5=RAS# Precharge=tRP
15=RAS# to Activate to Precharge=tRAS
Command Rate 2T
These settings should automatically populate in one of your EPP profiles.
-E
Oct 29, 2008 | ASUS Motherboard Striker II Formula
try to boot up with minimum configuration ie: graphic card , and memory, check BIOS configuration
Sep 25, 2008 | ASUS Motherboard Striker II Formula
New system won't work with memory in dual channel
Change RAM (SuperTalent 2x2G DDR2-800 PC6400 CL 5-5-5-15 (T800UX4GC5) this part
Jul 22, 2008 | Gigabyte Computers & Internet
No video
could be that the drivers are not correct for the monitor/videocard that you have set up. have you tried downloading some newer ones from your monitors manufacturer?
May 27, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Motherboard Issue
Hi Tomokato,
This maybe nothing but the first thing I checked is the CPU.
Supported CPU list through Asus web site for M2N-SLI
(Click on this link). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=M2N-SLI
The first supported 64 X2 is;
Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2
Second CPU supported;
Athlon 64 X2 3600+ (DD),1MB,65W,rev.G,SocketAM2
The CPU that you are using is not supported.
Since this is a new CPU, you might be able to exchange it for the Athlon 64 X2 3600+ (CU),512K,65W,rev.F2,SocketAM2.
Link to Asus main web site for M2N-SLI.
http://support.asus.com/download/download.aspx?modelname=M2N-SLI&SLanguage=en-us
Suggest you add the above link to you're favorites.
Even you're memory is not supported. As seen in user manual page. 2-13.
Have more questions, feel free to ask.
Mike
May 01, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Cmos checksum error
Dec 24, 2007 | ASUS A8V-VM Motherboard
Computer Not Booting Up
normaly ther are two reasons for pc not showing the disply
1 memory card mismach
2 graphics card mismach
get the specification of the mother board and correct the above errors the pc will work if u need more assistace please write to me
Oct 23, 2007 | ASUS AI Lifestyle P5N32-E SLI...
ASUS Motherboard Striker II Formula  Logo
231 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
