Question about Canon PowerShot A540 Digital Camera
Green Light Turns on, Sound of turning on, lens comes out, but then goes back in a turns off. . .It's not the batteries. PLEASE HELP ME!
  • cjogg May 25, 2008
    I turn on the camera. The green light is on. I zoom in for a picture. But the camera screen goes black and the camera lens goes in and off. The batteries are new and I don't why the camera automatically shuts off.
  • Canon Master
  • 4,738 Answers
Note that some batteries just don't hack it in digital cameras, even if new. This is especially true for those "super heavy duty" batteries:
http://camerarepair.blogspot.com/2008/02/simple-fix-for-digital-cameras.html
OK, so it's definitely not the batteries. A few of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on May 26, 2008
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
When I turn the power on, green power light comes on, lens comes out half way but then freezes and green light goes off, camera unresponsive. battery is fully charged and I have taken it out and put it...
Hi.
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Regards.
Aug 09, 2010 | Canon IXUS 960 IS Digital Camera
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
My camera comes on (the green light blicks) for about one second then goes to red and won't come on. I have replaced the batteries several times
The camera turns on and there is a green light on the camera and instantly turns red
Try to use the KODAK Lithium Digital Camera Battery CRV3 There is a red light because the camera has insufficient power and also the lens assembly might be defective try to use the battery i recommend
Sep 23, 2009 | Kodak EasyShare C633 Digital Camera
Green light, black screens, no sound, needs new battery???
The alarm is just a coincidence i suspect, green light comes on and stays on probably not the battery at fault. It would be red.
If the green light goes out and screens just flash one of your screens are at fault or a loose ribbon connection.
Jul 01, 2009 | Nintendo DS Lite Console
Goes off after lens come out.
Get it repaired under warranty. Sounds like a logic circuit problem.
Dec 10, 2008 | Pentax Optio S50 Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Aug 10, 2006 | Olympus FE-110 Digital Camera
Canon PowerShot A540 Digital Camera Logo
41 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
