Question about Sony Playstation 3 (PS3) Console
When my son switches on his ps3 there is an orange/yellow light on instead of green...can you indicate the reason for this please?
  • 4,102 Answers
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
p1
Posted on Sep 29, 2010
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
Diagnostic lights a green, b & c orange
Rear Lights Dell Computer Error Codes
Rear LEDS are labled A through D and can change from green to yellow. Some typical LED reading might be:
A - yellow, B - yellow, C - green, D - green <-- Indicates a problem with the RAM.
A - yellow, B - green, C - yellow, D - green <-- Indicates a problem with the video card.
Refer to the Dell website for your specific model, as these lights can vary from model to model.
see more from this site
Jan 16, 2014 | Dell Precision Workstation 670 PC Desktop
Trying to wire new stereo for my 98 taurus, but wire colors dont match up! where can i find factory stereo wiring schematics
Hello I have included a wire color code for you installation. Hope this helps you out. Please rate and good luck. Israel
Constant12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination light blue/red
Left Front + Orange/light green
Left fRont - light blue/white
Right Front + white/light green
Right Front - dark green/orange
Left Rear + gray/light blue
Left Rear - Tan/Yellow
Right Rear+ Orange/red
Right Rear - Brown/Pink
Apr 13, 2010 | Car Audio & Video
Ps3 will not switch on. The green light turns orange than red
This is known as the yellow light of death (ironic i know because it blinks red). This is caused when the unit overheats causing the solder on the board to melt and bridge(connect). Once this happens it shorts out the board causing the error you have now. Contact Sony and see if the unit is still under warranty.
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
Green light yellow light red light
Here is someone on eBay that does it also.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=380166005639&ssPageName=STRK:MESELX:IT
Nov 13, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not turning on
The only thing i can think of is click the switch to turn off the PS3 completely leave it off for about 30 second turn the switch back on and try again. If the doesn't work you may have a problem with your power supply and might need to get your PS3 serviced
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Car stereo wiring (1993 Ford Taurus GL)
My guess is that ford did not change that much in a year.
1994 Ford Taurus Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Green/Yellow
Radio Ignition Switched 12V+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Dimmer Wire: Light Blue/Red
Radio Antenna Trigger Wire: Orange/Blue
Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 6 1/2′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): White/Green
Right Front Speaker Wire (-): Green/Orange
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Pink/Light Green
Left Rear Speaker Wire (-): Dark Blue/Orange
Right Rear Speaker Wire (+): Pink/Light Blue
Right Rear Speaker Wire (-): Tan/White
Jan 13, 2008 | Car Audio & Video
Sony Playstation 3 (PS3) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
