Question about Canon PIXMA MX300 All-in-One Printer
The ink cartridge is half out on the wrong side. How can I remove it to replace with a new cartridge
  • Canon Master
  • 17,130 Answers
You will need to remove the catch on the cartridge so that it is released to be pulled out. So check this small lever to move off.
Once removed the replacement goes fit into the slot with the lock catch put on..
Posted on Sep 29, 2010
I replaced new cartridge in T1-5630 and it is not printing.
the reben is not proper settings in that fitings shapes if we miss side folds the rebens is not able to run in cartrideges then it jam reben stop but matter machine go reben comes side at print cames nothing
Jan 10, 2012 | Texas Instruments TI-5630 Calculator
I am getting an "there is no ink cartridge
Are you removing the seal (looks like tape) from the new cartridge before installing? It needs to be pulled off in order for electrical contacts to touch. Otherwise, may need to replace printer.
Jan 09, 2018 | Primera Technology PRIMERA Inkjet, 4-Color...
4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
  1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
  2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
  3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
  4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
  5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
    1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
    2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
    3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
    Figure 5: Aligning the ink cartridgesc00121093.jpg
Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
  8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
it's not a nice way of saying it but someone has to give you the bad news
Feb 01, 2010 | HP Office Equipment & Supplies
"WRONG CARTRIDGE" continues to flash on the screen.
I have experienced the "Wrong Cartridge" error about 4 times in four years. I have never bought a replacement print head. I do occasional printing each week. Typically the problem occurs after a color cartridge goes empty and the ink dried to the print head. The solution for me has been to remove the cartridges, remove the print head, place the print head in hot water in the kitchen sink (softens water based ink that has hardened)and then use a Q-Tip or tissue paper to clean the print head until it is nice and shiny. Reinstall the print head, insert ink cartridges that are not empty, let the printer cycle through a self-test, use the set button to accept vertical and horizontal print patterns and you'll be good to go!
If that doesn't fix it, you'll need to replace the printhead ($49-69 depending on where you buy it.
Oct 11, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Replaced two ink cartridges now the other one says it's empty. It was just half full before.
Try to reseat/ remove the cartridges and put it back in. If it is still the same, try to put the old ink in and check if it will still show half full, if it does, it means that there might be something wrong with the detector on your printer. But usually, printers have this issue but will fix itself in 24 hours. It is just a lag in the printer's counter
Sep 05, 2009 | Office Equipment & Supplies
HP 6310 printer ink Level doesen't indicate any ink in printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Poor and inconsistent quality from the black ink.
the problem seems to be un-even distribution of ink. try a different and new ink cartridge. Since you are refilling the cartridge, the ink inside of the cartridge is getting magnetized, there by, the ink stick to the drum of the cartridge and don't distribute the ink evenly. shake would clear it. you need to demagnetized the drum.
Feb 21, 2009 | Lexmark X4270 All-In-One InkJet Printer
Printer stopped printing colour
Are you using Name brand ,new ink cartridges?
Take the color cartridges out and make sure you removed the tape from the bottom of those cartridges. if done already take a wet paper towel and squeeze out the excess water, then lay the damp paper towel folded in half on a flat surface.
Then set the colored in cartridges one at a time with the ink side pressing against the damp paper towel for about 3 min. after 3 min you should see the ink drain on to the paper towel if so then replace the cartridge back into the printer and that should solve your problem.
Feb 14, 2009 | Canon i850 InkJet Photo Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Mp 460 tryin to insert ink for the 1st time
Your post is in the wrong place. I almost got you the wrong directions. LOL
Issue: How do I install the ink cartridge(s)?
Solution: Installing / removing ink cartridges MP160 / MP180 / MP460
Installing / Removing Ink Cartridges To print normally, install or remove ink cartridges in an orderly procedure. Installing ink cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
Nov 12, 2007 | Brother HL-2040 Laser Printer
Canon PIXMA MX300 All-in-One Printer Logo
27 people viewed this question
old marine
old marine
