Question about GoVideo Televison & Video
The open/close function does not work most of the time. I am unable to put DVD's in or take them out until perhaps the next day & then it still sticks again. D645 GoVideo DVD/CD player What is your phone #? I called 800-736-7679 & it was for a different company.
  • GoVideo Master
  • 1,550 Answers
You got some capacitors dried on the power supply of your dvd.
Posted on May 25, 2008
Why won't My words with friend open?
Sometimes an application can simply get stuck in a loop. Double tap your home button & you'll see a list of all your open apps. In iOS 6 or older you'll see the apps listed only at the bottom. Everything else will be blurred. Hold down on an app until they all wiggle & press the x to close all of them. In iOS 7 & newer they'll show up as slides. Simply swipe them up to close. I recommend a power cycle after doing this. Make sure the device is not plugged in. Hold the home button & power button at the same time until you see an apple on the screen. This will reboot & relaunch the software. It solves a lot of these performance problems.
May 02, 2014 | Apple iPad Tablets & eReaders
When I open the dvd lid, and I put the dvd in and close it, the screen still says its open and it wont do anything until the dvd lid is closed. Even though I close it, the player still thinks its open.
There is a mechanical switch that is operated by the lid as it's closed. Sometimes, a DVD player such as yours can be made to work by pressing down on the lid but this is a sure indication that something is wrong with the switch. It isn't practical to hold the lid down for the entire time you're viewing a movie so repair or replacement is the only solution
Nov 17, 2012 | Mintek MDP-1815 Portable DVD Player
Nitro 4326v Visor DVD and monitors: I purchased my set online from Vicspecial on ebay in July 2010. I didn't have them installed professionally until early Dec 2010. They initially worked. I had to put...
This is from almost SEVEN years ago!
"Nitro 4326v Visor DVD and monitors: I purchased my set online from Vicspecial on ebay in July 2010. I didn't have them installed professionally until early Dec 2010. They initially worked. I had to put the car in the shop for a brake and electrical problem the following day and when I got it out the DVD was not working but both monitors power on. Nothing from the DVD and the remote does not work on any of the functions of the DVD. Please help."
Jun 22, 2017 | Car Audio & Video
I am unable to open the dvd tray after inserting a dvd which plays ok.i want to be able to open and close the dvd tray as normal.
There may be a problem with the dvd you are using. If you look at the front of the dvd player there should be a very small hole. Take a paper clip and insert into this hole which should open the dvd drawer.
Now try another dvd to the if the player functions correctly. If not it likely means that there is a problem with your dvd player.
May 20, 2010 | Computers & Internet
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Disc tray won't stay closed.
I fixed this by jerking the tray gently. Someone jammed my tray and it skipped a few gear teeth. It seemed like the machine couldn't pull it in far enough to reach its preset position. So I let it close and when it was almost closed, I gently jerked it out to skip the gear teeth back into alignment. It is kind of tricky because the motor will just reverse instead of skipping teeth (you'll hear the plastic clicking when it skips). Perhaps unplug it and slowly push it in manually then **** it back out softly. Just be gentle. Good luck.
May 16, 2009 | Pioneer Televison & Video
How to fransfer video from vcr tapes to dvd
you done that the problem so. press power on bottom & press dvd section mark"open/ close" bottom & hold it untill show in dvd from vcr by lcd screen. if want dvd to vcr. you just playing vcr the system going to vcr section direct. good luck!
Mar 23, 2009 | LG RC-197 DVD Recorder/VCR
DVD Player won't open
check if your dvd door is driving by belt or gear . if its belt ,check if its slack, if gear check for worn gear. weather gear or belt check if the motor driving it responds each time you press the eject button .check if the eject switch is ok .then if all this are ok ,check the ic controlling the eject/close functions
Jul 11, 2008 | Samsung DVD-V1000 DVD Player/VCR
Does not respond to remote control
After power on the dvd, open the tray and put any video dvd in and close it, wait for about a minute, then press Setup or any button on remote control, if it work then need to replace with the new battery CR2025.
Jan 27, 2008 | Cyberhome DVR 1600 DVD Recorder
Televison & Video Logo
43 people viewed this question
Top GoVideo Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
