Question about Indesit 24 in. D63S Free-standing Dishwasher
The tablets are not dissolved properly - Indesit 24 in. D63S Free-standing Dishwasher
  • Indesit Master
  • 43,501 Answers
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Posted on Sep 29, 2010
Think the element or thermastate has gone as it's not disolving the tablets can I fix it myself
One of the first things to check if the dishwasher detergent is not dissolving is the water temperature that is in the dishwasher. If the water temperature is too cold, it may not be able to dissolve the tablet effectively. . If it is below 130 degrees Fahrenheit the setting needs to be increased or contact a plumber for assistance.
Read more : http://www.ehow.com/info_8597080_dishwasher-tablet-not-dissolving.html The Dishwasher Tablet Is Not Dissolving eHow
Nov 18, 2015 | Dishwashers
Not cleaning dishes properly
It means your water is not hot enough or you don't have enough water to dissolve the tablets. Please turn up your water tank for startes. If the problem persists, you will have to replace the heating element.
Mar 11, 2014 | Hotpoint Dishwashers
Dirty dishes
Some brands of powder do not dissolve properly, also it is not recommended to use the tablet type powder blocks as they don't work well and cost more than normal powder.
Mar 10, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher tablets dont dissolve properly
You really have to check if you have proper water flow inside the machine. My guess would be that you have a clog in the arm and therefore not enough water circulating in the machine to dissolve the soap. Check for a clog in the spray arms or around the pump housing and see if there is a restriction of some sort
Mar 10, 2011 | Dishwashers
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
TOP DRAWER WHEN LOADED, DOES NOT GET WASHED
top tray not washing properly and tablets not dissolving are linked. On my FDW60 same problem was down to the top tray not being pushed fully home (tendency to use closing the door to push top home). This meant the flap of the tablet 'hatch' was stopped from fully opening by the tray, also poor water pressure to drive the rotating sparge bar on the underside of the top tray.
Be sure to push the top tray all the way home BEFORE closing the door, aaannd SPENT!
Mar 17, 2009 | Dishwashers
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
I have a Chef Classic dishwasher - not washing properly
The caddy for cutlery on this model is in front of the compartment where you put the tablets. What'll sometimes happen, is a spatula or wooden spoon or something in the caddy will hold the tablet compartment lid shut - it'll stop them coming out properly.
After a while the water movement will move the obstruction and the tablet will come out, but it'll only be dissolved for a bit of the wash and the dishes won't be cleaned properly.
Dec 18, 2007 | Magic Chef CDB6100 Built-in Dishwasher
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Indesit 24 in. D63S Free-standing Dishwasher Logo
266 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
