Question about Logitech Z-2300 Computer Speakers
My left speaker is louder than the right one.... i have checked the left-right balance on my player and also the connector pins at the back of the sub... eveything seems fine... please help..
  • 30 Answers
This problem occurs a lot i even have this problem with mine. What i did to fix it is turn down the volume on the computer to in between 50-75. next set the balance on the computer's volume setting to a little more to the right one. It does take a little testing to see how far to the right you want it. I did this with mine and its like there is nothing wrong with it.
Posted on Jan 11, 2011
MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Feb 15, 2017 | Marantz Audio Players & Recorders
Audiosource amp 100 on lower volumes right speaker louder than left speaker 2.1 setup
The problem is not due to how the circuitry is configured; the problem is due to failure of some element in the right channel amplification circuit. This will require detailed troubleshooting to correct.
Dec 07, 2013 | Audio Players & Recorders
I don't know how to use behringer feedback destroyer DSP1124p
Determine where in the mixer's signal path to connect the unit. Your options are:
1. One or two individual microphone channels via the mixer's CHANNEL INSERT in/out jacks.
2. The monitor mix output via the mixer's MONITOR OUT jacks.
3. The main mix output via the mixer's MAIN OUT jacks.
  • 2 Connect a balanced cable with the appropriate connectors from CHANNEL INSERT OUT jacks on the desired mixer channel to INPUT RIGHT or LEFT on the Feedback Destroyer's back panel for individual microphone channels. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to that mixer channel's CHANNEL INSERT IN jack.
  • 3 Connect a balanced cable with the appropriate connectors from the mixer's MONITOR OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the monitor signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the monitor amplifier INPUT jack or amplified monitor speaker INPUT jacks.
  • 4 Connect a balanced cable with the appropriate connectors from the mixer's MAIN OUT jacks to the INPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel for the main mix (FOH) signal path. Connect a balanced cable with the appropriate connectors from the OUTPUT RIGHT or LEFT jacks on the Feedback Destroyer's back panel to the main amplifier INPUT jack or amplified house speaker INPUT jacks.
  • Oct 17, 2011 | Behringer Audio Players & Recorders
    The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
    The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
    This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
    Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
    2 ... ... ... 14
    1 ... .. ... 13
    The pinouts are:
    1 Mic in/center
    2 Ground
    3 Mic power/Bass
    4 Audio power
    5 Right line out/Speaker out Right
    6 Right line out/Speaker out Right
    7 Reserved
    8 Key
    9 Left line out/Speaker out Left
    10 Left line out/Speaker out Left
    11 Right line in/Rear speaker Right
    12 Right line in/Rear speaker Right
    13 Left line in/Rear speaker Left
    14 Left line in/Rear speaker Left
    Aug 27, 2009 | Biostar P4M800-M7A Motherboard
    Front left speaker is louder than the right one Replaced my altec lansing speakers because left speaker was louder than right. They were about 6 years old, replaced with Logitech 2300. Same problem. If I...
    JUST ADJUST THE BALANCE IN THE VOLUME CONTROL, YOU CAN FIND IT IN THE CONTROL PANEL OR AN ICON AT THE BOTTOM RIGHT OF YOUR SCREEN, THE RIGHT NEXT TO THE CLOCK.. PLEASE VOTE FOR MY POST
    Oct 29, 2008 | Audio Players & Recorders
    Im sittin here with the wiring harness for my 99 altima, and the wiring thing from the back of my pioneer deh p6700MP, i have no clue which ones to match with the other one?
    Here's the manual for the Pioneer -->LINK<--.
    This is the 2 options of install wiring on a 97 Altima, I'm not sure if it's exactly the same, I suggest that you don't trust these pinout if yours differ at all.
    Radio Constant 12V+ Wire: Pink
    Radio Switched 12V+ Wire: Blue
    Radio Ground Wire: Chassis
    Radio Illumination Wire: Red/Green
    Radio Dimmer Wire: Red/Yellow
    Antenna Trigger Wire: Green/White
    Front Speaker Size: 4′ x 6′
    Front Speaker Location: Doors
    Left Front Speaker Wire (+): Brown
    Left Front Speaker Wire (-): Black/Red
    Right Front Speaker Wire (+): Light Green
    Right Front Speaker Wire (-): Black/Yellow
    Rear Speaker Size: 6 1/2′
    Rear Speaker Location: Rear Deck
    Left Rear Speaker Wire (+): Orange
    Left Rear Speaker Wire (-): Black/Pink
    Right Rear Speaker Wire (+): Blue
    Right Rear Speaker Wire (-): Black/White
    THERE IS AN ALTERNATE WIRING COLOR CODE
    THERE IS NO CONTACT PIN OR EXISTING WIRE THAT IS GROUND !!!!! (some really strange things happen to aftermarket radios if you think the Red/yellow wire on pin 9 of the 10-pin connector is ground”!!!!!
    Large 10-Pin Connector:
    Constant Hot (Memory or Clock) =RED wire pin8
    Switched (Ignition) Hor = Blue wire pin4
    Left Front Speaker + = Blue/white pin1
    Left Front Speaker - = Blue/yellow pin5
    Right Front Speaker + = Brown pin2
    Right Front Speaker - = Brown/white pin6
    The Smaller (6-pin) connector is only for the rear Speaker:
    Left Rear + = Red pin5
    Left Rear - = Green pin4
    Right Rear + = Blue pin2
    Right Rear - = Pink pin6
    Regards
    Philip
    Jul 21, 2008 | Car Audio & Video
    Car amp high input pinout
    With a 4-pin connector - from left, facing the side of amp with RCAs and high level input:
    Left speaker + input, Left speaker - input, right speaker - input, right speaker + input
    With 5-pin connector - same as above, except center pin goes to ground and 2 right side pins are for right speaker.
    Feb 15, 2008 | Audiovox AMP522A Car Audio Amplifier
    JBL CREATURE II Computer Sattelite Speakers Sound Problem
    check on the speaker software were you can set master volumeetc. check for balance volume .
    Oct 27, 2007 | JBL CREATURE II Computer Speakers
    Durabrand Db1200 installation
    As per our chat session I said I would be back while I search out your product...so here is your information; http://dbproducts.net/i/product/manual/DB1200_OM.pdf
    Aug 24, 2007 | Durabrand DB1200 CD Player
    Logitech Z-2300 Computer Speakers Logo
    742 people viewed this question
    Top Logitech Audio Players & Recorders Experts
    Michial Gueffroy
    Jerry Umali
    Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
