Question about Canon Cameras
Canon SD1000 flash not working
Works fine when flash is turned 'off', but when on a picture will not take and the flash icon 'flashes'.  I fear my daughter may have dropped it.  they want $97 (estimate) to look at it.  Camera cost $199.  Do I dump it or can I try to fix, or can I get external flash??
  • rose323 Jun 10, 2008
    the camera works when the flash is off but the pictures come out dark but doesnt work when the flash is on and the flash button appears on the screen
This happened to my SD1000 and I followed the step by step instructions shown here:
http://www.ifixit.com/Guide/Replacing+Canon+PowerShot+SD1000+Broken+Flash+Unit/7778/1
and when I got to step 15, I found that the small plug that connects the flash to the camera body had been disconnected when the camera had been dropped. I simply pressed the connection back in tight and reassembled the camera - and it works. Maybe this happened to yours too??
Posted on Oct 15, 2013
  • 374 Answers
SOURCE: Casio EX-Z57 Flash not working
Try resetting your camera and see if that helps. Sometimes it does. In REC mode press menu go to setup tab go up to reset press right arrow & highlight reset press set. If that doesn't work you are probably going to have to send it in.
Posted on Jul 16, 2007
SOURCE: Flash icon blinks red, but won't work.
Most likely flash is worthless like mine.
Posted on Aug 31, 2008
futureloginn
  • 734 Answers
SOURCE: Canon Powershot A550 flash will not work it just blinks on & off?
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Posted on Dec 04, 2008
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
  • 10865 Answers
SOURCE: My flash quit working
You are correct in saying that the bulb needs to be replaced. Take the camera to any camera shop and they will replace it for you.
Posted on Apr 20, 2009
My canon powershot SD 1000 will take outdoor pictures but wont take any with low light and the flash won't work. I see that someone else asked the same question but I can see what advice was offered
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Recommend trying the pencil tapping fix listed in the link. It worked on my SD1000 with the same problem.
Jun 04, 2011 | Canon PowerShot SD1000 Digital Camera
How do I turn off the flash on my Cannon pouershopt SD1000?
Hello and Welcome to FixYa!
To turn off the flash follow the given steps:-
  • Turn on your Canon PowerShot SD1000 Digital Camera
  • Press the Flash Right Arrow button on the four-way control on the back of your camera to display flash options on the camera's LCD screen
  • Now push the Left Arrow or Right Arrow button to select the flash "OFF" icon. It's the third icon that display the flash symbol crossed out by a backslash symbol inside the circle.
I hope this solution helps you
For Further assistance, I am here to help
Thank you and Keep using FixYa!
Jun 02, 2011 | Canon PowerShot SD1000 Digital Camera
Flash Does not work. canon sd1000
Dec 10, 2009 | Canon PowerShot SD1000 Digital Camera
I have the same problem
The weaker the battery, the longer it takes the flash to charge. After taking a flash picture, you're supposed to wait until the flash has recharged before pushing the shutter button again.
Sep 13, 2009 | Canon PowerShot SD1000 Digital Camera
Apr 20, 2009 | Canon PowerShot SD1000 Digital Camera
CANON SD1000 STOPPED FLASHING
I had the same prob. try changing the capacitor attached to the flash
Nov 25, 2008 | Canon PowerShot SD1000 Digital Camera
Canon Powershot SD1000. Not allowing to take pictures
Hi
Try turning the flash off and see if you can then take pictures. If that works then your flash is defective and needs to be replaced.
We are a digital camera repair business (Google Darntoothysam) and we can do that repair for you for a very reasonable price, or you can look for a defective camera online and make one good camera from the two.
Good luck from Darntoothysam com
Thomas
Oct 22, 2008 | Canon PowerShot SD1000 Digital Camera
Flash not working
Anyone found a soluton for this? My Ixus 700 worked fine one day, but the next the flash wont go off. The little flash icon is showing on LCD and the red eye reduction lights as well but the camera wont tae the picture!
Dec 23, 2007 | Cameras
Cameras Logo
333 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
