I am running win 7 & when tried to install xp its showing compatibility problem . pl reply
    Guru:
  • 1,481 Answers
Remember.... the OS compatibility is only lower to upper...not upper to lower....i.e.....
Win7 is higher than WinXP....so u cant run / install WinXP using Win7...but u can do the otherway round....i.e...1st u can install WinXP in C: drive, then let the machine start, once u get to WinXp dekstop then install Win7 in D: drive...(it's called Dual Boot)...so on the boot screen u can choose which OS to work with when the PC starts....
all the best
pls revert back...and kindly leave a rating and feedback to this solution...it will help me become a "Guru" here on Fixya....
regards...
Posted on Sep 29, 2010
I bought a LENOVO B 450 laptop. The dealer installed WIN 7. But in WIN 7 Tally 7.2 will not work. So I wish to install WIN XP. But when I tried to install WIN XP there shows an error message and a blue...
Please note that installing an operating system on an OEM machine OTHER than what was factory-installed on it may void either phone support for the customized OS or the warranty itself.
Lenovo Machines, like most new OEM models are set, by default to run their hard drives in AHCI mode for better performance & power management. Go to the computer's system setup F1 or Del while the computer is starting up to locate the Power, Hard drive or System configuration (Lenovo computers have different System Setup formats for each model so you'll have to navigate around a bit since they may be labeled differently).
Once you find it, you have to change the setting from AHCI to IDE or Compatibility, whichever option is available (once again, each model has a different format & labeling convention). Save the changes & exit the setup & retry the installation. Should work.
Aug 13, 2011 | Computers & Internet
I hve got 2 operating systems :xp & 7 in my machine. Where in Xp my Frontech E-cam:JIL-2225 works without any problem in all skype,msn n in yahoo messenger where in windows 7 it doesn't works ....
The error message which you gets in win7 is the issue for webcam drivers, Try to completely remove the driver and reinstall it back and check whether you using the drivers for windows 7 and try.
Regards,
JJ
May 13, 2011 | Computers & Internet
Hello I am trying to find a Canon iP 1000 driver but can't seem to find it online. Also, if and when I get it... will it run on Windows 7 OS?
There Is NO driver for Win 7. It is just that simple. No driver has been nor I suspect ever will be written for Win 7.
The best shot is to try installing, a Win XP driver, and installing and then running as Admin, & set "Compatibility Mode for XP SP2" this may work, and enable basic functions?
May 12, 2011 | Computers & Internet
SIR, MY WINDOWS 7 NOT DETECTING MY SONY CCD-TVR608 HANDYCAM.
only WIndows XP drivers are available for this device :
http://esupport.sony.com/US/perl/swu-list.pl?mdl=CCDTRV608&SelectOS=7#div_pos_18
try to install the drivers in compatibility mode
right click on setup
go to properties
go to compatibility
set it to win xp sp2
hit ok
run setup as administrator
ignore any error and hit continue anyway during installation
restart pc
if the above trick doesn't work then use the device in VIRTUAL XP MACHINE
us XP MODE or VMWARE..
Mar 05, 2011 | Sony Handycam CCD-TRV608 Camcorder
I need driver for windows 7
The driver for XP should work. You can find it here: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_d646u#DriversAndSoftware
Mar 01, 2011 | Canon CanoScan D646U Flatbed Scanner
I have Windows 7 and it my daughters hello kitty photo booth (digital camera kit) said that it would only support up to VISTA which I had until I upgraded.....how can I get this to work on my Windows 7?
Have you tried installing it on Win 7? Most software made for vista will run fine on Win 7. Otherwise you can try running the program in "XP Compatability Mode". You can do this by right clicking the installation file (or if installed already, the shortcut you use to open the program) and click properties. Then click the Compatability tab and check "run this program in compatability mode for:" and choose Windows XP (Service Pack 2)
Good Luck
Jan 21, 2011 | Cameras
This used to work perfectly on windows XP. I now have windows 7 & after downloading the Photo Explosion 2.0, it won't open & the programme just freezes. Help.
Downloading means you retrive any files and save to your PC/Laptop from any web source!
Installing means you install any software/programs to run on your PC/Laptop.
As for your software "Photo Explosion 2.0" could not run on Win 7 due to software "Compatibility Issues".
You can try, using "Win 7 compatibility mode" installing older software read this LINK
NOTE**
"There is no guarantees older software will work using Win 7 compatibility mode!"
Hope it helps.
Nov 11, 2010 | OnDemand Photo Explosion Deluxe 2.0 for PC
Hello my motherboard is Asus P5LD2 SE i hadn't any problem in Win XP but recently i have installed Win 7 (ultimated) that unfortunately audio driver doesn't work please send me audio driver...
this is the link for your driver it is working in windows 7 show i request you to you please try to download this driver from the above link http://in.asus.com/product.aspx?P_ID=ly0uHyAg2GI5nzmr&templete=2
Oct 09, 2010 | Computers & Internet
Since i changed from windows XP to Windows7 i can't connect my qtek to my pc. can anyone help me? thank you!
It is simply Win 7, it will NOT play well with what it considers "OLD" stuff. You could try Compatability Mode for XP SP2, and running the installer and the program as administrator. Right click on installer & after, the programs .exe and set compatability as related, then run as administrator thats the only shot you got sorry. Unless of course the manufacturer has a driver for Win 7?
Feb 21, 2010 | T-Mobile Dash Smartphone
Open Questions:
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
