Question about Gateway GM5084 PC Desktop
Gateway GM 5084 Ethernet
I cannot connect to the internet. when i try ipconfig, it says "media disconnected". this pc has integrated ethernet. what can i do.
my router does not recognize the ethernet connection so my wireless network is down.
    Sergeant:
  • 458 Answers
Are the drivers installed? Look in your device manager for the drivers. You might need a new Ethernet card. Also check in the BIOS to see if it is turned on. Try hitting the delete key or one of the F keys when it starts to get to the BIOS.
Posted on May 29, 2008
Can you tell me the default IP address for this unit as I have lost the pass word and need to reset the unit
If your computer is plugged into the router, you can easily get the router's IP address by going to your command prompt and typing "ipconfig" without the quotes.
Command Prompt is under Start (or Orb if using Win7 or Vista) > All Programs > Accessories
After typing "Ipconfig" and hitting return, command prompt should display something like this:
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : blah.blah.comcast.net.
IP Address. . . . . . . . . . . . : 192.168.0.196
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter PdaNet Broadband Connection:
The router's address is your "Default Gateway." You should be able to put that address into an Internet Explorer window and it will bring up the configuration interface.
If you find this helpful, please rate me -- trying to get my "Wiz" rating so that I can provide Premium service.
Thanks,
Chris
Jul 27, 2011 | 2wire 2700HG-B Router (2700HGB)
Aspire 5100 PC Notebook: How do i get my new Acer Laptop to connect to the ...
hi guest, welcome to the forum! Let me think why your laptop cannot access to internet during it's already connected to your router.
1) Because the connection is established --> Wireless is working properly
2) If you cannot access to Internet --> Access Restrictions is configured in Router.
How to configure?
1) Login to Router Administrator, you need to open a command line and use usage as ipconfig and you will see as the following
C:Documents and Settingssin.le>ipconfig
IP Address. . . . . . . . . . . . : 192.168.1.102
Default Gateway . . . . . . . . . : 192.168.1.1
Please open Internet Explorer with the address
http://Default Gateway ~ http://192.168.1.1
You need to know What is User name & Password to login, please configure "Access Restrictions" to allow access
I hope this is your case.
May 18, 2010 | Acer Aspire 5100 Notebook
I think my network card is bad. My internet / email isn't working on my desktop (although it works fine on my laptop). And the computer is not recognizing anything when I type ipconfig. So, i think i need...
since the network card is built onto the motherboard reinstalling the driver would be the best first option.
HERE is the link to the driver.
Broadcom827.exe - Broadcom NetXtreme Gigabit Ethernet driver Version: 8.27.1.0
Supports: Windows XP
Note: This is the Broadcom NetXtreme Gigabit Ethernet driver for use with the Big Lake, Cortez, and Putton Bay motherboards in Windows XP.
I would try that first.
Apr 14, 2010 | Gateway GX7022E (RBGX7022E) PC Desktop
How to enable WPA security. i tried to enter the http://www.192.168.0.1 but the page is not showing theres no admin page.help pls
Try http://192.168.0.1 - you don't enter www. in front of an IP. Check that this is actually your routers IP address by doing Start > Run. Type "cmd" without the quotes and press Ok. In the black window that pops up, type "ipconfig" without the quotes. You'll see something like this:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\root>ipconfig
IP Address. . . . . . . . . . . . : 192.168.0.2
Ethernet adapter Local Area Connection 2:
Ethernet adapter Bluetooth Network Connection:
If your Default Gateway Value is 192.168.0.1 then you're good to go, otherwise this value will be what your routers address will probably be.
Mar 01, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Media disconnected
If you are using one box (or modem/router) only, when your computer says media disconnected, it means that your computer does not detect your modem.
You can try unplugging and replugging the ethernet at the back of your computer or laptop. make sure that the light on the ethernet port is lit up (especially for desktops, not sure about laptops though).
You can also do the same process with the ethernet cable from your modem/router. if your modem/router has other ethernet ports in it, try to connect it to other ports as well. If your computer still says media disconnected, try purchasing or borrowing a new ethernet cable.
Also make sure that your ethernet adapter is working properly and that media disconnected follows after ethernet adapter local area connection and not wireless connection.
Hope this helps!
May 04, 2009 | D-Link AirPlus DI-524 Wireless Router
Ethernet connection isn't working
Go to Start, Run, enter ipconfig. It will show IP, gateway ect. Then in the msdos window that comes up enter ipconfig\release then ipconfig\renew
Mar 15, 2009 | Zyxel Prestige 660HW Wireless Router...
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
Gateway GM5084 PC Desktop Logo
159 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
