Question about HP LaserJet 3600n Printer
My 3600n hp laserjet printer is not printing when i print adobe file the Error is come. Pcl Xl Error Subsystem: Kernel Error : Missingdata Operator : Vendorunique Position : 46
3 Suggested Answers
shawasim
  • 4 Answers
SOURCE: PCL XL LASERJET 2550L
Download The PS driver from hp.com.. u might be using a PCL 6 driver.
Got to www.hp.com
Click on support & drivers.
Select Download drivers & software
enter ur product.
Select the OS on ur comp.
Download PS driver & install it.
Try This
All the Best!!!!!!!!!!1
Posted on Jan 09, 2009
SOURCE: We have an HP 3600 printer we are trying to use
It is colour laserjet or all-in-one printer.If it is all-in-one try it->
    1. Select Start , Printers and Faxes .
    2. Right-click the HP All-in-one PCL6 icon, and select Printing Preferences from the drop-down menu.
    3. Select the Paper/Quality tab.
    4. Select a lower resolution such as 600 dpi, and then click OK .
    5. Click OK to close the remaining window.
    6. Print a test page from the document or application in question.
  1. Enable Send True Type as bitmap in the PCL6 print driver.
    3. Select the Advanced tab.
    4. Select Enable next to Send True Type as Bitmap, located under Printer Features in theDocument Options section of the print driver, and then click OK .
Posted on Jun 07, 2011
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
Pcl xl error subsystem: kernel error: illegal tag operator: ox1b position: 6
If you are using Windows 2003 Server and/or Windows XP Client machine and if you hace installed PCL 6 Driver than printer will print pcl xl error while printing.
To fix this problem user need to install PCL 5 Printer driver or Universal printer Drivers from the Link mentioned.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1845552&prodTypeId=18972&prodSeriesId=1845551&swLang=8&taskId=135&swEnvOID=228
Jun 29, 2009 | HP LaserJet P2015 Printer
Printing problems
GO ON LINE AND TYPE IN THE FOLLOWING INFORMATION.
EXCEL ERROR PCL XL ERROR
ENTER
LASERJET ERROR KERNEL ILLEGAL OPERATORS SEQUENCE ENDCHAR POSITION 293
ENTER
CALL THE MANUFACTURES CUSTOMER SERVICE LINE AND ASK FOR TECHN SUPPORT AND GET THE RIGHT ANSWER TO THIS COMPLEX QUESTION PLEASE
ROD GANDY
Jan 22, 2009 | HP LaserJet 4250n Printer
PCL XL error
Please uninstall the current PCL driver and upgrade the same with UPD PCL5 (dont install PCL6) from http://www.hp.com/go/upd
Regards,
Nikhil
Dec 16, 2008 | HP LaserJet 1320n Printer
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
Jul 28, 2008 | HP LaserJet 3050 All-In-One Printer
Pcl xl error , subsystem:kernel, Error: Illegal tag
Change paper to plain instead of UNSPECIFIED in the printing properties. The printer hates the UNSPECIFIED setting.
Jul 26, 2008 | HP LaserJet 1320n Printer
Printing error
when i send for print i et
PCL XL error
subsystem: KERNEL
Error: IllegalTag
Operator: 0x1b
Posittion: 7
Jun 15, 2008 | HP LaserJet 6p Printer
Printing problem "PCL XL error"
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
May 29, 2008 | HP LaserJet 1320n Printer
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
Apr 12, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3600n Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
