Question about Sony PlayStation Portable (PSP) Console
USB fails to recognize my PSP
The screen reads "One of the USB device connected to the computer has malfunctioned, and Windows cannot recognize it."
    Scholar:
  • 102 Answers
What are you trying to do? connect it to the computer?
if so try a new usb cable. if that dont work look inside the female ubs jack on the psp make sure all the pins are there. see if it wiggles any.
you might need to replace the ubs port on your psp. which is a soldering job.
contact us for professional help. United.Gamez@Gmail.com
Posted on May 25, 2008
My computer dosent run my psp program with a usb cable so i can sync anything in, how do i make it recognize my psp
When you connect your PSP to your computer, it won't recognize the PSP immediately. After you connect the PSP, you will have to navigate to USB Mode on the XMB. Your computer will recognize your PSP as a mass storage device.
Good Luck.
Mar 18, 2011 | Sony PlayStation Portable (PSP) Console
Dont kno how to put music and videos in my psp
Putting music or videos on the PSP is a fairly simple and straightforward process.
What you'll need:
  • a mini USB to USB cable (to connect the PSP to the computer)
  • a memory stick (to store your music and videos)
Instructions:
  1. Put the memory stick in the PSP.
  2. Connect the PSP with the mini USB to USB cable to the computer
  3. On the PSP, go to the settings menu and select "USB Connection."
  4. Your computer should recognize that a device has been connected to it, open up the device (your PSP) inside a file viewer, such as windows explorer. There should be a few folders here one named Video and one named Music.
  5. Add the music and video files to these folders, and press O(circle) on the PSP to end the USB Connection.
  6. If all has gone right, and the files are the correct formats, you should be able to enjoy your music and videos on your PSP.
Mar 13, 2011 | Sony PlayStation Portable (PSP) Console
When i installed the media player into my computer. i get a little screen saying usb device not recognized. one of usb devices attachedto this computer has malfunction,and windows does not recognize it....
Hi, smpk4083 mp3 player not recognized by the computer
Why is my smpk4083 mp3 player not being detected by my computer when I connect it?
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see smpk4083 mp3 player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the smpk4083 mp3 player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: smpk4083 mp3 Players can connect to your computer in MSC or MTP mode. Exceptions are smpk4083 mp3 player Connect and smpk4083 mp3 Express which only use MTP mode. MTP mode is the recommended and default method for smpk4083 mp3 Players when used with Windows OS.
The smpk4083 mp3 player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
Hope it helped.
Have a nice day,.
Feb 22, 2011 | Sylvania Audio Players & Recorders
Usb device not recognized, usb device malfunction windows does not recognize it
Connect it to a different computer, to see if the USB port on your computer was the problem, or if the USB device itself is the problem.
Dec 25, 2009 | Verbatim External, USB 2.0, 750GB...
Windows Vista will not recognize dell axim X3
I have had that problem with other USB devices i suggest trying a different USB port as the USB port you have used to connect the X3 to is most likely malfunctioning.
Aug 10, 2009 | Dell Axim X3 Pocket PC
PSP Driver
What are you trying to do with the PSP? Are you current with all updates?
Go here:
http://www.us.playstation.com/PSN/mediamanager/
Dec 25, 2008 | Video Game Consoles & Games
Tried the solution you offered for c240....
Go to Start --> Control Panel --> Printers and Other Hardware --> System --> hardware --> device manager --> right click on the usb port that is malfunctioning (should have a red or yellow exclamation by it), right-click it and click on Update Driver
If that fails, try another USB port on the computer to see if you have more success
Jun 23, 2008 | SanDisk Sansa c240 MP3 Player
Unknown device
this is an error message stating that. the usb device is faulty.
It has detected that the usb port has an error/fault or problem.
check that non of the pins are touching each other, or that dirt or dust isn,t inside the usb connection port. blow in it. or use a cotton bud to swab it out.
Mike @ Compurepair.
Feb 23, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
106 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
