Question about Mitsubishi WD-52825 52" Rear Projection HDTV
Picture problem with 2005 Mitsubishi 52' WD-52825
The TV shows horizontal lines when watching from the cable. Seems to differ in intensity from channel to channel. HD channels are the least affected. When playing the DVD the lines are different. They are much larger and run almost vertical as the roll across the screen. I’ve changed the DLP-Bulb trice and no change. I’ve replaced the DVD player and no change.
I first suspected or it acted like a signal problem. I ruled that out because a signal problem shouldn’t affect the DVD player. Anyone have any ideas?
Thank You,
Clyde Simons
Clyde@NextFrontierMedia.com
  • precisehome Mar 09, 2009
    Same here. Happened once I put in a new lamp
2 Suggested Answers
  • 179 Answers
SOURCE: Mitsubishi Mod. WD-52825 projection tv
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Posted on Dec 29, 2008
Hi, Where is the power supply board located within the WD-52825 rear projection tv?
Its in the very front of the metal encased chassis block underneath the sloped top shield. The Power cord plugs directly into the power board.
Jul 30, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Oct 31, 2008 | Mitsubishi WD-52825 52" Rear Projection...
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replaced lamp in WD-52825 but still no picture. Lamp indicator on.
the DM board has gone bad. it is not the 4 100uf caps on the board. it is surface mount parts. it this board has failed then the FMT board is not far behind. the chassis needs to be rebuilt. www.tv-techs.com
Aug 29, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi WD-52825 Noise issue
Good Day, mooredriven;
If the picture looks like checker board pattern the TV may have a problem with part:
D8F00 PART # 264P828010-diode-DAN202U/MA142W
D8FO1 " " " " "
C8F26 " 141P148000 CER (B25K-1M-K)
C8F29 " " " "
OR the formatter board #930B924001, on that board there are 5 caps 1000 ufd 35v that commonly go bad.
Good Luck, big irish.
Jul 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blue lines
DB-IF IN FACT THE PIX IS GOOD ON OTHER INPUTS THEN YOU MAY HAVE A BAD FORMAT PCB.IF THE LINES ARE ALSO ON ALL OTHER INPUTS YOU PROBABLY HAVE A DETERIORATING POWER PC BD. PROBABLE COST OF REPAIR 350.00- 700.00.JOE TV
Oct 11, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52825 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
