Question about Itochu C.itoh CI 5000 Matrix Printer
Citoh ci 5000 giving a a21 home error at switch on if head is moved then switched on head returns to home as normal but if print is tried a22 motor error is displayed
  • jannie_dekoc Sep 29, 2010
    Not the fuse and i replaced the head motor problem stays
  • 4,924 Answers
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
If this will not fix it ..it means that the issue is mechanical and this will explain the second error ..and the mechanical thing will be on the motor that drives the print head..
Posted on Sep 29, 2010
  • Catalin Turcu
    Catalin Turcu Sep 29, 2010
    if you check that ...and you know it is not he head motor ...than is the head print or the drum itself ..or just some small spring not in place ..cause i see no other issue ..
    Try to reset it ...again if you didnt do it ...
Print motor error
The Print head assembly is not able to move to its home position probably some debris could be stopping it from moving to home position check and clean as necessary
Jun 26, 2015 | Xerox Phaser Office Equipment & Supplies
My cannon printer mp510 gives me an error code 5000
No problem that's why I asked I couldn't find a 5000 error for this machine. Open the cover and wait for the print head to come to the center, then pull the power cord from the back of the printer. Once the power is off you can now move the carriage to the far left so it is out of the way. Now use a paper towel and gently blot all the excess ink off of the ink Pads inside the machine on the far right and press them down. If the Wiper blade is extended, clean it and it should snap back in position. If it is still stuck, try sparying the area with Windex but don't get any on anything except the pads.
Mar 04, 2015 | Cannon Office Equipment & Supplies
I have a minolta 4050 that is showing a 601 error code
SC 601 = SCP board PWB J malfunction or scanner motor malfunction.Scanner motor located in rear parts right side and the PWB J panel in the right side of copier.Try open and closed the front door,push the trouble reset switch,if the error code persisit change the scanner motor or PWBJ.Move the scanner manually,turn ON the power switch,if the scanner exposure lamp move,working the scanner motor is OK.Check the scanner home position sensor.
Oct 30, 2011 | Minolta EP4000/5000 CS/PRO Copier
Error6A+MP810 No print, no scan, no normal operation
12 times AP position error [6A00] An error occurred in the AP motor during purging
operation.
- Sheet feed unit
- Purge unit
- Logic board*
Try to manually move print head at left position and then try torotate the gears of purge unit, if it moves (purge unit) switch off and on printer
Jan 12, 2010 | Canon PIXMA MP810 All-In-One InkJet...
Need the XP driver for the citoh ci-5000. Was working well on old computer... it died, I connected it to another computer and I can't find the driver... please help, I need this asap THANKS Will
copy past this downbelow in your browser pick os
http://citizeneurope.com/drivers/dotmat.htm
Oct 06, 2009 | Itochu C.itoh CI 5000 Matrix Printer
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Alps MD 5000
Did you pack the printer correctly before moving? When you got the printer, it would have had a packing piece preventing any carriage movement. If you did not put this in place before packing the printer for the move, you have most likely damaged the printer beyond repair.
May 22, 2008 | Alps MD 5000 Thermal Printer
Error code A21
Aug 30, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Home Error
Apr 02, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
146 people viewed this question
Top Itochu Office Equipment & Supplies Experts
k24674
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
