Question about Electrolux 23 in. ESL6114 Built-in Dishwasher
My machine is a ELS 6115 We had a power cut during a dishwasher cycle. Ever since the alarm sounds after a short while and when one opens the door the pump continues to run. Turning it off and back on resets the program seemingly however the alarm sounds and the program indicator light flashes. If held down to cancel the three hour delay light shows and the pump continues to run. The only way to stop it is to turn it off?
  • Electrolux Master
  • 3,247 Answers
The symptoms you have are that of the flood switch in the dishwasher has been activated.
I am assuming when the power cut happened there must have been some delay after which it came back.
Somehow water has leaked into the base under the heater assembly. You will have to open the base and find the flood switch and dry it. Also need to replace gasket / door seal if leaky.
Posted on Sep 29, 2010
Bosch dishwasher trips power supply when door fully opened after cycle completes
The dishwasher will have a wiring harness which passes through one of the corners or in the centre of the door. I would suggest that the harness has perished or weakened and exposed a live wire which touches the cabinet when the door is opened and it shorts out. Opening and closing the door after many years of use weakens the wires where they get continually bent back and forth during door opening and closing. Ive seen wires rejoined but the only sure fix is the replace the wiring harness.
Feb 23, 2015 | Bosch Dishwashers
MDB7600aws Maytag dishwasher heats up with door shut when off
Your timer is jamming on the heat cycle. When you open the door the door interlock switch cuts the power off and stops the cycle.
Probably if you just close the door again it will heat again unless the machine is started again.
You need to repair or replace the timer.
Mar 16, 2010 | Dishwashers
My lg door will not unlock
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power
Mar 14, 2010 | LG WD-12126RD Front Load Washer / Dryer
Washer loader door is locked and i cant open it
this kind of door lock is called PTC door lock.It is designed for protecing you from opening the dooe during the washing and spining cycles which may hurt you.So, if you want to open the dooe during cycles,pls press "stop",then ,wait 2 mins,you will be able to open it by then.the other situation is that,the power is cut off during working cycles,solution is:re-start the washer and directly open the door.Pls note that this kind of lock has to work under power.
Mar 14, 2010 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
Opened door during cycle, latch now stuck in closed position, can't re-close
twist a paperclip around some pliers so you have a circle opening. then hook the paperclip around the latch and pull outward with the pliers. once the latch is facing outwards the door should close again
May 30, 2009 | Bosch Evolution 500 SHE45M06UC Built-in...
Dishwasher problem
First: this is what Whirlpool says!!
And after this at the bottom Is what the repair manual says when I looked it up for you!
Dishwasher is not operating properly
1.Dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
2.Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
3.Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
4.Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
5.Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
6.Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
7.Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
___________________________________________________________
BUT, the repair manual says this
Faulty Pump and Motor Assembly Some models that will not wash or drain often have a faulty Pump and Motor Assembly. If the motor is receiving power from the timer and it is not operating that is the case.
Temporary Work-around:
With the power turned off to the unit, sometimes it is possible to manually rotate the cooling fan on the motor assembly. In certain situations where the dishwasher has set idle for a period of time, this may free the bearings enough that the unit will begin to operate. Where this works as a short term solution in some cases, it is often a sign of things to come. The frequency of the motor seizing will increase until it will simply no longer work.
I think this is a hands job that needs service and hands on attention!
I hope it's not the motor or pump!
How old is the machine?
If they tell you it is an expensive motor then you need to know this!!!!
Let me know how it goes!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
Oct 10, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch #SHU9955 Integra dishwasher for the last three uses, the soap dispenser door was open with the powder soap caked in the lowest one half of the pocket dispenser. The dispenser door locked and unlocked...
The problem was evident during short cycle (primary cycle used) and changing to regular cycle used and back to short cycle seems to have corrected problem.
Oct 09, 2008 | Bosch Dishwashers
Dishwasher
Make sure that you do not open the door during the wash cycle. Wait until all the cycles are complete before opening the door. Especially don't open the door during the drying cycle.
Mar 20, 2008 | Dishwashers
Electrolux 23 in. ESL6114 Built-in Dishwasher Logo
148 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
