Question about Pool & Spa
I got a Infinty spa from a friend and i was at work when it was dropped off and i was wondering how do i hook it up, i looked for a cord but did not have any luck. could you please reply on how to hook it up
    Novelist:
  • 116 Answers
Normally you only see plugs, or cords on a 110v spa, and those are usually smaller more portable units. Anything 220v will normally be hooked up directly from a junction box to the spa control box, via a watertight conduit. I don't work on stand alone spas too often, So I can't say specifically to your situation without seeing the actual unit, or a couple pictures, but there should be a panel that you can remove to access the underside of the spa. There will be a panel, or box that contains some electric/electronic stuff. This should have a hookup for your electric. It should have a ground, a neutral, and two hot connections, usually one red and one black. Here's an example of what one looks like that I pulled off the web with a quick search... http://i231.photobucket.com/albums/ee106/kengorman/DSCF8380.jpg Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Posted on Sep 29, 2010
How to wire t55cxbnc-999
CAREFULL . look at the side of the motor it has the diagram. now for the wire colors WHITE is common, BLACK is high, RED is low. most cases, but if someone has tampered with the wires. use a voltmeter and check- White and the red and black should change when switching the spa control speed, and double check your work, cuz if hooked up wrong it will burn up the motor in a matter of seconds !
Or search your area for your local pool pump repair guy with free testing, bring the cord and the motor to him or her and have them attach the cord.
Jay
Jan 29, 2015 | Pool & Spa
A friend gave me a Hayward Comfortzone pool heater several years ago, I have not used it yet but might, wondering how I could get a manual for installation and hook up etc.
Hayward no longer offer parts or any other support for the old Comfortzone heaters but you can follow the general guidlines from any of the Hayward heaters as far as gas line sizing, spacing requirements and piping. This one on the H-Series should work...
https://www.hayward-pool.com/pdf/manuals/Manual285.pdf
John
May 15, 2011 | Hayward Pool & Spa
I have a old tube cb base station gemtronics 5000gtx i found in trash years ago its missing the ac powercord but has the round plug that a powercord would be soldered onto was wondering how you would...
My book shows 3 different configurations on one all but 2 of the pins are hooked up. If you want you could look the hook up info online. Or call the folks at (706) 270 3829 they will send you a email with it in it for free.
Sep 06, 2010 | Radio Communications
Ordered new pump at pool store. they put old cord on new motor and i got it home and it does not run . i think they may wired it wrong but they closed til mon. thanks
YOU MIGHT HAVE A BAD CORD .. USE A VOLT METER TO CHECK POWER AT THE MOTOR.. ON THE SIDE OF THE MOTOR THERE IS A WIRING DIGRAM LOOK AT IT TO SEE IF ITS HOOKED UP RIGHT.. DID YOU CHECK ALL OF THE BREAKERS ???
Aug 21, 2010 | AO Smith Centurion 1081 1 Hp Standard...
I have an Infinty Bass Link hooked up to my 2002 Honda Accord sedan for extended bass response on the standard stereo. I hook it up with premium power cables, etc...according to manual. I then hooked it up...
Does the servo led stay on? If so, you might have a fractured solder joint. Inspect the switch control PCB for fractured solder joints and check the Positive and Negative 15v outputs on the same board.
Jan 14, 2010 | Infinity BASSLINK Car Subwoofer
Pool & Spa Logo
63 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
