Question about Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive
My fantom drive greendrive green light is flashing what should i do
    Master:
  • 636 Answers
Its an issue with connectivity.
Check the USB connection.
Posted on Sep 29, 2010
Fantom Greendrive 1TB Power Switch Broken
I'd suggest a techie guy would be the fastest and the cheapest way
Mar 25, 2017 | Computers & Internet
My Fantom Greendrive is not being recognized by my computer whats the problem?
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 10, 2012 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
How can I create multiple partitions on my 1TB fantom Drive?
Use a partition manager program like
http://www.partition-tool.com/
Aug 19, 2011 | Fantom Drives GForce GreenDrive 1 TB USB...
I want to replace the drive, how do i take the enlosure apart to do this?
Hello there,
If you see a screw, unscrew it and pry the casing out. Then there should be two cables inside that is connected to the harddisk.
Hope this helps.
Apr 29, 2011 | Fantom Drives GForce GreenDrive 1 TB USB...
Not recogize green drive
Hi my I know the operating system of your pc?and if you restart your PC?
Dec 17, 2010 | Fantom Drives GForce GreenDrive 1 TB USB...
When i turn on my fantom green drive the green light keeps flashing
If the light turns on (mine was blue) but the drive is not recognized on your computer desktop that most likely means the drive does not have enough power. This happened to me too, and I took it to a computer expert and he said the drive was not even spinning. So it was either the external power source that broke or the internal power source, the power panel that broke. I took it to a batter plus and tested the wattage for the external power source and it was okay so then i took the entire drive apart and disconnected the naked hard drive from the power panel. Then I purchased "SATA to USB" cables (runs around 10-20 bucks) and connected the naked hard drive that way to the computer and it worked. So the problem is basically that the internal power panel is not working, and i had 2 fantom drives that both had this problem and they both worked after i did what i just said.. so I think your drive has the same problem since the light comes on but the drive is not spinning. Take it apart, buy some SATA to USB cables and it should work.
Sep 30, 2010 | Fantom Drives 120 GB Hard Drive
Which is better for my external hard drive?
click on safely remove hardware icon and stop the device when your done using it
May 14, 2010 | Fantom Drives GForce GreenDrive 1 TB USB...
Unusual sounds, doesn't show up in My Computer
The hard drive is damaged my friend. Hard drives are very,very, very delicate pieces of equipment. The disk is paper thin and any sudden jarring, sometimes can occur in transit and especially dropping it creates a warp in the drive. Unplug it to prevent further damage. Don't worry in many cases you can have the data retrieved from your hard drive by using this online company that I highly recommend:
http://www.gillware.com/
Jul 06, 2009 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Fantom G-Force MegaDisk 1.0TB 7200RPM USB 2.0 16mb cache (MDU1000) Hard Drive Logo
515 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
