Question about Whirlpool Duet GHW9150P Front Load Washer
Problem How do i reset my washer?
    President:
  • 1,314 Answers
Push pause cancel twice
Posted on May 24, 2008
Is there a reset button or someway to get the washer back on besides having to wait for it to come back
on some models the motor reset is done by unplugging it for a couple minutes then plug it back in, on others u can open and close the lid slightly not fully 6 times within a 12 second period and it will reset the motor. on others u have to push start, cancel or some other buttons, to reset appliance. u can check the manual or youtube on how to do ur specific model
Jan 15, 2015 | Washing Machines
Resetting washer
FOR MOST JUST UNPLUGGING AND RE PLUGGING BACK UP SHOULD RESET UNIT. IF YOU HAVE MANUEL CHECK TO SEE IF THERE IS A TEST MODE YOU CAN PUT IT IN AFTER UNPLUGGING AND REPLUGGING .
Mar 03, 2010 | Maytag EPIC MFW9700S Front Load Washer
How reset clean washer reminder on Bravos washer
This is just a factory setting that reminds you to clean the washer to avoid that musty smell. You can buy tablets called Affresh or other similar cleaners for washing machines. They sell these items at Target, Walmart, Lowes and Home Depot. You can also substitue 1 Cup of Bleach in the washer. Then once you add whatever solution you have decided to clean it with you simply select the wash cycle on the machine called "Clean Washer with Affresh" Once you have done this the light should go out. You can also reset this indicator light by pushing the button next to the light that says Reset clean washer reminder. Hope this helps!! :)
Jan 14, 2010 | Maytag Bravos MTW6600T Top Load Washer
All lights and signals are on and won't turn off on my whirlpool duet washer, and nothing works. how can I reset?
Reset the washer by unplugging the unit for at least 30 minutes. This will reset the Central Control Unit (CCU). If the problem reoccurs following a CCU reset, let me know. I hope this helps you.
Jul 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Mar 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Keep needing to reset washer dryer
Check the vent lines to be sure the path is clear
Mar 13, 2009 | GE WSXH208A Front Load Washer
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
