Question about Samsung AS18A6RB Air Conditioner
I have 2 samsung split a/c units in a room. I have the condenser with 2 compressors on the roof. It has one circuit board. One of the compressors works and the other does not. When I turn on the room unit that is attached to that compressor, the unit in the room starts and in about 10 to 15 seconds it shuts off and then a red light flashes. What would the problem be?
  • 1 more comment
  • ftmtechservi Sep 29, 2010
    Thanks for your response. The compressor does not turn on at all. The unit is not overloading. The evaporator inside is the one that turns on for a few seconds and turns off and then it shows a red flashing light.
    The compressor does not turn on. The unit inside the room turns on and shuts off within seconds. Then the light starts flashing red.
  • ftmtechservi Sep 30, 2010
    Hi and thanks for your response. I wanted to give you some more information to make sure I narrow the problem down. The unit is a Samsung multi split system heat pump model ad18b1c09. There are two falshing lights on the inside unit, One is green and one is orange. This is the unit that turns off after a few seconds. Any thoughts? Thank you in advance.
    President:
  • 1,796 Answers
The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.)
If this problem if not addressed on time, is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician.
On the other hand, If you have some electrical knowledge and are not afraid of working with 220v, let me know and we can do some testing. You'll need a voltmeter and some basic tools. Good luck!!
Posted on Sep 29, 2010
  • 1 more comment
  • Rene J Solis Sep 29, 2010
    Ok, that changes everything. let me get you more info.
    Hi!!
    We need to know if when you turn on your unit, the compressor starts up. Have someone turn the unit inside while you check outside, if the compressor starts and then shuts down, or, if the compressor doesn't even try to start at all, then, replace/fix the PCB (circuit board). If he compressor tries to start and it can't, then replace the compressor's starting capacitor.
    Turn breaker to off position,
    TO REMOVE CAPACITOR
    gain access to capacitor and use a screw driver to touch the capacitor terminals, this is to discharge the capacitor. take a picture or label electrical connections. disconnect wires from capacitor and remove it.
    TO REMOVE PCB
    1 Open the front grille by lifting the tabs on the lower right and left sides of
    the indoor unit.
    2 Disassemble the front grille by pulling it forwards.
    3 Hold the edge of the air filter under the front grille and pull to release them.
    4 Remove screw fastening the plastic cover to the left of the unit
    5 Take a picture and label wires and plugs on the PCB before disconnect.
    6 Remove PCB
    If you are electricity savvy, no need to be an expert, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad, replace it yourself and save, the component is only a couple of bucks. Or buy the whole PCB. Good luck. Keep me posted.
  • Rene J Solis Sep 30, 2010
    That's exactly what I figure the problem to be. The solution is just for that problem. Good Luck!!
Why is it that the compressor not working but the condenser fan is running?
have a technician check it but it probably is the control board on the outside unit.
Mar 16, 2015 | Samsung AQV18VBEX Mini-Split Air...
Econair split system
Hi Dominic, can I get more info about this installation? About the height between indoor and outdoor unit?thanks!!
Feb 03, 2014 | Heating & Cooling
The unit either encountered a brown out or a surge which burned up the board for the condenser. It had black marks on the board and the indoor unit was flashing. Replaced the board and the unit is still...
After replacing the burned condenser board, check also the entire condensing unit if still ok ( compressor and fan motor). If the light inside the indoor unit is still flashing, the timer is still not giving signal for the compressor to start. Adjust temperature and wait for 3-5 minutes. It light continue flashing, there is something wrong with the indoor unit control.
Sep 02, 2011 | Sanyo Split System Air Conditioner
I have samsung wall type split,working normally for some time then make a small beep indoor unit then the compressor turns off..
The unit is locking out...find out where to check the "code" that tells why... usually on the outdoor unit circuit board...
heatman101
Aug 28, 2010 | Samsung AS18A6RB Air Conditioner
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
I have this air conditioning unit where suddenly stops functioning and no power on the indicator. i have thecked the breaker and it is fine and ON with a three phase supply. I've checked the condenser at...
Hi, I will see if I can give you some idea of what may be happening. I work on these on a day to day basis. So, you have a split system with the condensing unit on the roof, or a package unit on the roof? Sounds to me it is the first one.So, you are telling me that the power supply at breaker below is OK, but you should have a power box at the condenser on the roof. When you reset power to the condenser, that's when you here this blast sound? To me from just hearing what you are saying , it would be the sound of the compressor trying to start up, and it has a internal problem making this noise. Tell me, when it makes this noise, does it trip the breaker again? If so, it is definatley the compressor. You can prove this if you are inclined to do this, is to find the 3 different wires going to compressor, and make sure power is off 1st. Disconnect them at the Contactor or remove the plastc cover from compressor and write down which wire goes to each terminal.Tape the ends so they dont touch metal. Turn the condenser back on and see if this blast is gone. If so, the compressor is dead and you will need a new one.You say you have 3 phase power? This is unusuall for a residential unit, 3 phase units are for comercial unit power. They dont use starting componants like Run or start caps because they have enough power to do the job.3 phase would have 3 hot legs of equal voltage unless it was the older 3 phase which will have a stinger leg with higher voltage then the 2 other legs.Maybe this is a commercial a/c. Also, the compressor is reversable on a 3 phase unit by moving 2 of the 3 wires on the load side of the box, like T-2 and T-3. If these are switched if the compressor is locked up, sometimes you can get lucky and break it loose.Please don't do this, I am just explaining to you a little about 3 phase. Try this so you can elimanate the compressor. The only other thing it could be, if this is a gas pack and you are starting the heat, you can be getting blow back premature combustion? But I don't think this is what you have. It has to be the compressor.So, lets prove it by taking it out of the circuit. all should hold and no noise.Still, a faulty compressor is not a good thing. Let me no. Best of Luck and safety first.
Sincerely,
Shastalaker7
Nov 25, 2009 | Air Purifiers
Does not heat - compressor switches on/off repeatedly
check outdoor fan if running. the outdoor coil will freeze up on heat cycle. or outdoor board if there is one is defective.it could be reversing valve as well
May 18, 2009 | Heating & Cooling
Samsung AW1003M Air Conditioner how to clean Fan inside??
hello! there well, there are two fan coupled together on a/c the condenser fan and blower fan,if this is split type the fan and blower are separated.the procedure is the same way.doing this release lock off and take off front cover then pull out ac unit assembly,after pull out,open terminal control box disconnected all wiring connected on compressor motor and fan motor, loosen all stud bolt on compressor blower fan case.this well exposed fan and blower w/ the motor.cover the motor of plastic sheet then, pressurize water wiil use to clean blower fan observed the motor not to wet by water if this wet don't try to run let it dry off or else this wii burn out so take all necessary precaution, beside mosly cleaning procedure includes the fin tube of condenser and evaporator there are foriegn particles and moisture emerged in evaporator mostly that why insufficient cooling effect on condenser heat rejection also affected if dirty fin tube emerged,.theres is lye detergent use and mix to water pour this to evaporator and condenser fin tube wait for 15 to 30 min soaking to rinse dirt will come out to fin.observed not to distorted fin of tube on eveaporator and condenser.,then pressurise this by water again if cleaning was done dry it off until all dirt disappear.if finishe put back all casing of compressor,evaporator and condenser, then connect all electrical control connection on circuit board, double check connection just put back what ever disconnected parts dont try to alter specially electrical control connection on circuit board.this is a hard task and risky if yout not qualified to handle this job bring it or call a service technician.have a nice and cool day regards and thank's.
Mar 29, 2009 | Samsung AW1003M Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
289 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
