Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Icemaker stopped making ice
Our whirlpool refrigerator (which is 3 years old) has a broken ice chute so...we reach in for it but now the ice maker isn't even making ice. It made a knocking when it did at the end and then stopped altogether. I love ice and don't know what to do. Whirlpool says I need a new door for the chute, I can live without that but the maker needs to make ice. Please help.
Thanks,
Laurie
    President:
  • 1,314 Answers
Remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on May 24, 2008
Whirlpool Ice maker broken
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with.
Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
You can determine which ice maker you need by checking at the Whirlpool website on icemakers.
Whirlpool Refrigerator Ice Makers Replacement Parts Accessories PartSelect
If you have determined that you cannot fix your existing icemaker, try checking Amazon for a replacement.
Amazon com whirlpool ice maker replacement
Feb 09, 2018 | Whirlpool Refrigerators
Icemaker on side by side not working
Change out your ice maker. If your icemaker has worked for 6 years, you got lucky! They normally have to be changed out every couple of years. We have an unlimited inventory of appliance parts for Whirlpool, so please call us to send your parts out and we'll get them out right away!
Sep 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Mar 30, 2009 | Refrigerators
ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Ice Maker Won't release ice
Jetguy77,
I have a 1993 year (16 years old now) Whirlpool side-by-side with icemaker, Model ED22PW. I have had similar problems with the icemaker - water goes in, freezes, but ice does not eject from tray. It has happened to this unit 2 times since 1993. It turns out the problem is not the thermostat. It is the icemaker motor module. The icemaker has a small synchronous (clock) motor that rotates the ice ejector. When it goes bad, the ejector does not rotate, either because the module timer had failed or the motor itself has failed. The solution is to go to your nearest applinace parts dealer and by a new "icemaker motor module" for Whirlpool Model (your model here). Mine cost $58.85 the last time I replaced it in 2006. To install the new module, you will need to remove the icemaker from the refrigerator. Mine has 3 screws that attach it to the side. Also unplug the power & control cable. The water tube slides out when you pull the unit forward. When you get it out, it is then easy to remove the motor module and insert the new one. You may have to reset the timer on the module to get the tray to fill completely.
Jan 18, 2009 | Whirlpool GS6NBEXR Side by Side...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Huuum
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Kenmore Icemaker
check inside the ice maker are the forks pointing up or down if they are down them the module on front of ice maker is broken it needs to be repl, but you said is 8 years ol d so i would repl the whole ice maker since the mold might be peeling off due to age they only last like 4 years or so
Jun 11, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Ice maker stopped working
are the "fingers" of the icemaker pointed toward you and slightly up? if not the icemaker is internally broken . is the red light to the right blinking twice and then a one second pause? if not the emmitter is broken. is the black hose coming from the ceiling blocked with ice ? if so the water vave is broken allowing water to seep in hose and freeze. hope this helps.
Feb 08, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Sep 05, 2007 | Whirlpool ED2FHEXN Side by Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
151 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
