Question about Dell A940 All-In-One InkJet Printer
Dell A940 printer - says hardware error 0502- have tried disconnecting lead fro printer an laptop [ as per manual] no go - what now please?
  • purple_anne Sep 29, 2010
    Thank you - the printer is now working
  • Dell Master
  • 19,396 Answers
Hi.
Check and eventually clean the encoder strip and the rail where the ink carriage is sliding.
I report a more elaborate procedure from Fixyourownprinter, here the original:
Hardware Error 0502 on LCD Display ID:ENUS16536
Check the encoder strip on the printer. (This is a clear strip running the length of the printer, above or behind the cartridge carrier.) Do the following:
1. Switch off the printer using the power button.
2. Disconnect the power cable from the back of the Lexmark
3. Leave the power cable disconnected for 30 seconds.
4. Slide the cartridge carrier to the middle of the printer by taking the top part of the belt and moving it gently to the right.
5. Take out both cartridges.
6. Place an index finger on the encoder strip on either side of the cartridge carrier.
7. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into. Slightly push the encoder strip down and then back up to get it into the slot.
8. Lightly press the strip first to the rear and then forward, if necessary.
9. Clean the encoder strip with a dry tissue. Also clean the contacts of the printer.
10. Reconnect the power cable and switch the printer on again.
11. Perform the hardware test without cartridges first and then with both cartridges.*
12. Make a standalone copy.
13. If the copy is satisfactory, repeat the test once to confirm that the error is gone.
Check also this useful blog with pictures on the problem: Lexmark printers with "Hardware Error 0502?
Posted on Sep 29, 2010
    Brigadier General:
  • 3,917 Answers
For this type of issue turn on the printer. Pull the cartridge to the middle if it . Clean the cartridge with the soft cloth. Reinsert the cartridge. Restart the print. Just wipe this rod with a kleenex and the problem seems to go away.
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Dell AIO A940 is giving me an error code 0502 and won't print. Says it is busy?
Check this out for the error. The trick here is to make sure the bar is cleaned and lubricated with furniture polish or cooking oil.
May 24, 2010 | Dell A940 All-In-One InkJet Printer
My dell a940 printer has a 0502 error how do i fix it
Hi Remcountrybo,
You can fix this by following the instructions given in the following link.
Fix Error 0502 in A940 All In One InkJet.
-Rate if it helped you.
Apr 10, 2010 | Dell A940 All-In-One InkJet Printer
What is a Hardware Error 0502 displayed on an
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 15, 2010 | Dell A940 All-In-One InkJet Printer
Hi: my name is Roland I have a dell a10 error 0502
Hi there
Hope this will do the trick
Nov 19, 2009 | Dell A940 All-In-One InkJet Printer
I have Dell A940 printer-I was printing some documnets and suddenly the printer stock and it was written on the screen: Hardware Error: 0502.What do I need to do?
Unplug your printer and re-start windows. Do a normal shut down and then start windows again with your printer plugged back in
Make sure that you have the newest driver installed from Dell you can go to support.dell.ca to obtain the latest release of your driver.
May 25, 2009 | Dell A940 All-In-One InkJet Printer
Wont finish print job hardware error 0502????
I found this:
Hope it helps!
Mar 28, 2009 | Dell A940 All-In-One InkJet Printer
Dell all in one printer 940
try holding the power down for 15 seconds
Mar 06, 2008 | Dell A940 All-In-One InkJet Printer
Hardware error message
Here is a link to the error code that you are receiving and it includes a troubleshoot. http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=true&docid=3448BE8E41616B39E040A68F5B28300D&journalid=18CBB4A8572211DCAEB7A5F38B3D0A57&l=en&s=dhs Hope this helps:) Jason
Aug 30, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
43 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
