Question about Philips Magnavox MWR10D6 DVD Recorder
It won't turn on.
I have unplugged it to reset it. That hasn't worked. Could it be the fuse? If so where is it and how do I check it?
  • DaisyPup Jul 01, 2008
    Thank you for the info. I tried this and it still didn't fix the problem. If anyone out there has a second solution to fixing the problem, it would be appreciated.
  • Anonymous Nov 29, 2008
    Same trouble. It won't power up. Fuse is good.
I am having a similar dilemma. A solution would be most appreciated.
Posted on Aug 03, 2008
  • 4 Answers
I'm having the same problem. The fuse is underneath the top panel which can be easily removed by removing all the small screws on the unit. The fuse is located towards the back of the unit just to the right of the disc casing. It's a small glass tube and is similar looking to a fuse used in christmas lights but this one is much larger. I haven't had the chance to go buy a new fuse but mine doesn't appear to be blown because there is no discoloration on the glass and the rod inside is fully intact but I am hoping it may still be bad. Once I have the chance to get a new I'll reply with any results. Anyway, hope this helps ya, naybe you can get your fixed too!
Posted on Jun 24, 2008
Won't work. No service code.
the first things to check is the door switch,open the door and push in the switch,if it doesn\'t click when pushed in the switch is bad,next thing to check is the belt,on some models there\'s a switch on the pulley assy. if there isn\'t any tension on the pulley the dryer won\'t start.if you need more help i need the model number off of the dryer,open the door and lolook around the opening where you put the clothes in and you\'ll see a tag with the model number,if the dryer hasn\'t been taken apart and cleaned out the thermal fuse could have popped,if the dryer gets to hot inside from a blocked vent line or the duct that the lint filter slides into is blocked the fuse will pop and it\'s non resetable.
Mar 18, 2013 | Kenmore Dryers
Kenwood 6.1 dvd screen won't turn on, but reset
It appears that you may have battery power but, no accessory power. Check you radio fuse in the vehicle and, behind the radio.
Feb 06, 2013 | Car Audio & Video
I can't connect two Xboxes to my one router! For
Reset the router with both wires unplugged.
Plug one xbox in and turn it on, once it's connected connect the other the same way.
If you're trying to log in to xbox live using the same account on both xbox's you won't be able to.
Feb 03, 2012 | Computers & Internet
I have a 91 olds supreme 3.1 v6 it shut off and won't start back .... It starts but won't turn over.... And when turn the key back off it's blows the dis fuse wich mean direct ignition system...
Check the coils that have been replace for bent or broken prongs that plug into the ignition control module and if nothing looks damaged then i would think the ignition control module is faulty.Replace ignition control module.
Jan 21, 2012 | 1991 Oldsmobile Cutlass Supreme
Vw polo abs light won't go off. I've replaced the 40 amp strip fuse located in the fuse comparment above the battery but it still hasn't gone off even thought the orginal fuse was blown. Anyone...
Well, first of all, did you fix the problem that caused the fuse to blow? Have you scanned you Antilock Brake System (ABS) module for fault codes? Since the computer is the one responsible for turning the light on, wouldn't you think that the computer would be the one to ask WHY it has turned the light on?
Please also review the following articles:
Where's The Fuse?
What Else Could Be Wrong?
Sep 11, 2011 | 2002 Volkswagen Golf
19 inch slyvania tv/dvd combo turn on play button stays on and the the tv goes to red green yellow and blue screen and won't do anything else
I have been having just about the same problem with mine, i can watch the tv for about 20 min and then the dvd player comes on by itself then it goes to red, green, yellow, and black and white, i've tried resetting the dvd player to default but it hasn't helped mine.When i try to turn it off it automaticly comes back on so i have to unplug it.If i find a way to make mine work right i will send you a message to let you know so you can try it on yours. I've had mine just over a year and i don't have a warrenty anymore.
Aug 08, 2011 | Sylvania LD195SSX 19 in. LCD TV
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
06 hyundai monsoon radio won,t turn on.
Just got an update from a dealer that might work...take the head unit out and unplug the power for about 30 sec. plug back in and the unit should basically reset itself. If that doesn't work I'm out of guesses.
Dec 27, 2008 | 2006 Hyundai Santa Fe
Philips Magnavox MWR10D6 DVD Recorder Logo
103 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
