Question about Xerox Phaser 6120N Printer
Error 15 Transfer belt - Xerox Phaser 6120N Printer
I have a problem about transfer belt error 14
Error 14 is actually the transfer roller, error 16 is the transfer belt.
Error 14 is a transfer roller error and roller needs to be replaced. The part number is 059E05450 and can be ordered below:
http://www.iteminconline.com/059e05450_059e05450-xerox-6120-transfer-roller.htm
Jul 30, 2015 | Xerox Phaser 6120N Printer
How do i Fix Error Code 2152 Konica Minolta Biz-hub
Code: C2152 Code C2152 Description Transfer belt pressure welding alienation
• During a retraction operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its retracted position within a predetermined period of time after the transfer belt retraction clutch is turned ON. • During a pressure operation of the transfer belt, the transfer belt retraction sensor cannot detect the transfer belt at its pressed position within a predetermined period of time after the transfer belt clutch is turned ON. Remedy 1 Check the M5 connector for proper connection and correct as necessary. 2 PS31 I/O check, sensor check. 3 CL7 operation check. 4 M5 operation check. 5 Change CL7. 6 Change M21. 7 Change PRCB.
Jan 29, 2015 | Konica Minolta bizhub Office Equipment &...
Ricoh sc452
That error code is related to Paper transfer belt contact motor error
The paper transfer belt contact motor drives beyond the specified time during home position detection or contact operation.Broken harness or defective connectors. Disconnected connector of paper transfer belt contact sensor or motor. Defective paper transfer belt contact motor. Paper transfer belt unit not installed try to change the motor
Oct 24, 2013 | Office Equipment & Supplies
Error 917
917 Error in the Transfer Unit Belt. The Belt Rotation Sensor indicates an error.
Code 917: The Transfer Belt Rotation Sensor indicates a belt error.
Initial Actions:
? Check the condition of the Transfer Unit drive gear.
? Cycle the printer's power.
? If the problem persists follow the procedure below.
Troubleshooting Procedure Table
1 Test the Belt Rotation Sensor.
Run the Service Diagnostics Belt Hole IC test.
Does the sensor function correctly?
Yes) Go to Step 2.
No)Replace the sensor. If the error persists, go to Step 3.
2 Test the Transfer Unit Motor.
a. Close the Interlock Switches for test.
b. Run the Service Diagnostics Transfer
Belt Motor test.
Does the motor operate?
Yes)Replace the Transfer Unit. If the error persists, go to Step 3.
No)Replace the motor. If the error persists, go to Step 3.
3 Check all pins on the HALL1 Harness for continuity.
Disconnect HALL1 and P/J310
Is the harness conductive?
Yes)Replace the Motor Driver Board.If the error persists, go to Step 4.
No)Replace the HALL1 Harness.
4 Check all pins of the DRV0 harness for continuity.
Disconnect the DRV0 ribbon cable.
Is the cable conductive?
Yes)Replace the Engine Control Board.
No)Replace the DRV0 Harness.
Aug 18, 2011 | Xerox Phaser 7400/DT Laser Printer
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Xerox phaser6110MFP transfer belt error cant
Transfer Belt Error Aproblem has occurred transfer belt in the machine. Unplug the power cord and plug it back in.If the problem persists
Cleaning the inside of the sensor of the belt and then not change you change the blet assembly moz-screenshot-1.jpgmoz-screenshot.jpg
Apr 22, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Service Call 15H
FATAL ERROR CODE 15H / SERVICE CALL 15 XFER BELT: Incorrect pressure
by or separation from the transfer belt cleaner
something wrong with the transfer belt
Apr 01, 2009 | Konica Minolta magicolor 2300DL Laser...
Power Off/On Fatal Error : 917
The 917 fatal error is a belt **** se sensor error. This could be caused by the belt not installed correctly or the belt at the end of its life, or the belt being torn. Please power the printer off and then reseat the transfer belt and then power the printer back on. If the error remains then I will need you to check the life remaining on the transfer belt. Also make sure the transfer belt is not torn.
Aug 08, 2008 | Xante Ilumina Digital Color Press Printer
Minolta QMS 2350 showing service call 15 xfer belt
Your error means -
Incorrect pressure by or separation from the transfer belt cleaner
Remedy
1 - Check the Belt cleaner positioning sensor pc9 (located at the rear on the left hand side towards the top when looking from the front of the printer)
2 - Replace the Second image transfer roller pressure/separation
mechanisms.
3 - Check the Image transfer roller pressure contact solenoid SL2 (this sits more in the middle behind the printhead)
4 - Replace PWB-A.
5 - Replace PWB-P.
Jul 05, 2008 | Minolta Office Equipment & Supplies
Xerox Phaser 6120N Printer Logo
81 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
