Question about HP PSC 2355 All-In-One InkJet Printer
What will be the cost ok black cartridge? How many pages will one cartridge print?
  • HP Master
  • 1,679 Answers
HP PSC 2355 Printer uses HP 94 Black and it can print upto 400 pages approximately
there should not be any problems except that it is 4-5 years old printer
Posted on Sep 29, 2010
SOURCE: hp officejet 6110 not printing with black ink
I think I know what is the problem. I refilled my black ink cartridge and it printed for a while, but at some point it just stopped working. The head wouldn't touch the paper. Initially I thought the printer had a problem, but then I discovered that the color cartridge still worked.I had a spare new cartridge so I changed it. Everything worked just fine afterwards. My hypothesis is that HP tracks an identifier in the cartridge and does NOT allow you to refill (I even think they simulate for the cartridge to be failing, but I still have to corroborate this). I think this is outrageous and illegal. Please let other people with the same problem know about it. So, the solution is to stop using HP products.
Posted on Dec 05, 2008
  • 26 Answers
SOURCE: MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Posted on Aug 18, 2009
ohms
  • 1879 Answers
SOURCE: My CX4800 is printing blank pages. I just changed
-use printer head cleaning utility
-change cart
Posted on Sep 04, 2009
  • 615 Answers
SOURCE: new black ink cartridge won't print for Brother MFC-290C
run software cleaning function for the heads and run the alignment, make sure that you move all the stickers from the cartridges and the vent hole is clear, clean the inside housing from any dry ink...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 20, 2009
  • 164 Answers
SOURCE: black cartridge emptied half way
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most walmart pharmacy departments.
*Warning: You may want to usea pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Patience
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent aeound it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, slternately sloshing/swishing and pouring solvent over head (be carefull not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY,with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
What will be cost per page of printing in hp lasure jet 2600
This is going to depend greatly on what type of printing you are doing as well as if you use OEM HP toner cartridges or go with a cheaper aftermarket cartridge. At the low end, this machine will cost you 2.5 cents per page for Black & White and 15 cents per page for Color. On the high end it will be closer to 5 cents for Black and 20+ cents for Color. The percentage of toner coverage will also obviously effect you per page printing cost as a page with more coverage is using more toner than one with less coverage. Keep in mind that the stated yield that each cartridge will produce is based on an industry standard of about 5% covergae which is not much when compared to the typical printing of most users.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 08, 2011 | HP Color LaserJet 2600n Printer
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
Black ink cartridge almost empty in just two days of use..why?
its all in simple math, when you go to by new ink cartridges it should tell you how many pages on average it should be able to print so price/page*15=cost to print a day
Feb 09, 2010 | HP OfficeJet J4580 All-In-One InkJet...
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
After changing printer cartridge, all printed pages have 3 black horizontal lines across the page about an inch apart.
It sounds to me that you need to run the clean print cartridges utility.
  1. Press the Setup button.
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK . The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
    1. Open the Printer Toolbox . There are two ways to do this:
    1. Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
    1. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
    2. If above does not work, then remove the black cartridge, and olace it upside down in an area it won't be disturbed for an hour, then place it back in the printer, and print a test page. (This only applies to black cartridges)
    Oct 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
    Gradually stopped printing, first colors, then black. New cartridges no help.
    check all the catridge installed ok after finding the gatridge ok if the problem not solved , then uninstall the printer driver and restart after restarting the machine then again reinstall the printer driver properly
    May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
    Is there a override function to keep printing when toner alerts are on?Wondering since black still shows 30%.
    These printers will still print when any or all of the toners are LOW, but if any one of them is EMPTY (according to the chip on the toner cartridge) printing stops.
    Standard capacity toners ere 2000 page for the colours, and 3000 page for the black, so they can soon be used up.
    Much cheaper per page printed, if you use the high capacity cartridges (6000 page for the colours, and 8000 page black).
    There are high quality remanufactured cartridges available now, as good as OEM, and typically you'll get a Hi Capacity Remanufactured cartridge for the same sort of price as a Std Capacity OEM cartridge.
    As a short term solution at a lower cost than replacement cartridges, you could just replace the cartridge CHIP. The printer would then think the toner was full (there'll likely to still be some toner in it), so you'll be able to print. Don't run the printer like this for ever though, as the toner has some lubricant properties, and with a TRULY EMPTY cartridge, you'll eventually do some damage to the cartridge, and then possibly the transfer belt (and you don't want to be changing that until it's rated 100,000 page life is up.
    May 01, 2009 | Xerox Phaser™ 6180DN Laser Printer
    I HAVE A HP DESKJET 940C PRINTER. BLACK PRINTING PROBLEMS.
    I GOT A CLARIFICATION REQUEST AND I SENT FURTHER INFORMATION BUT AS OF YET I HAVE NOT RECIEVED ANY FURTHER INFORMATION BACK FROM "KEEPITSIMPLE".
    Jan 27, 2009 | HP DeskJet 940c InkJet Printer
    HP Photosmart C3100 series
    I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
    Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
    HP PSC 2355 All-In-One InkJet Printer Logo
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
