Question about GE PSS26SGRSS Stainless Steel Side by Side Refrigerator
Power on Interior lights on refrigerator does not operate not cool
  • GE Master
  • 17,130 Answers
The interior lamps fail to light up as the swittch is faulty , so replace teh door switch if a contact cleaning wont help.
Now the cooling is related to many issues, so shut off fridge to allow time of 5 hours, The restart , if the fridge does not cool , the compressor , gas pressure is done and must be checked. If cooling is present then check if the auto defrost timer/thermostat is faulty as the fridge might stop cooling after 12 hours.
Posted on Sep 29, 2010
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
My dm2652 turns on but doesn't cool
Check the thermostat setting and check you have power from it to the heater if it is an absorption fridge or compressor if not.
Apr 21, 2012 | Dometic RM2652 Refrigerator
My model 106.53206202 compressor stops working about every six months. The interior light lights so there is power. I unplug the power cord and when I plug the power back in the compressor works fine. ...
I think the defrost timer/control board is hanging up...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 09, 2011 | Kenmore Refrigerators
Interior light stays on...light is hot..food directly beneath light is not cooling
HI. There is a door switch that controls the interior lights. This switch is also connected to the fan motor circuits. The actual door switches will be the lone culprits in your case. They are not functioning at this moment. This switch fault will effect the cooling process and cause an abnormally high temperature inside the unit, due to no Evap fan action and interior light heat.
Simply replace the door switches to correct the issue.
Sep 04, 2010 | Viking DDBB363 Bottom Freezer Refrigerator
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE PSS26SGRSS Stainless Steel Side by Side Refrigerator Logo
109 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
