Question about Sovereign ARP-900E Air Conditioner
Have tried multiple outlets but the unit doesnt turn on
  • Sovereign Master
  • 17,129 Answers
Possible that the compressor motor , the motor relay , the motor capacitor is faulty.
You will have to use a voltmeter to check the power to flow from the plug to the control switch/panel and the output to the relay.
If power comes to click relay the compressor must work if capacitor is good , if not the motor needs a check.
Posted on Sep 29, 2010
    President:
  • 1,796 Answers
Try draining the unit. If the drain pan is full, the unit won't turn on.
New B&D 22-inch hedge trimmer will not turn on. Power cord is plugged in and tried on multiple outlets.
Its time to return it and get another one. You should never try any thing on a unit that is under warranty. Thanks
Oct 23, 2013 | Black & Decker 22 In Dual Action Hedge...
Tv doesnt power up
most likely a power supply issue which is very common . You can get tech assistance and replacement power supply boards from www.tvrepairworld.com
Jun 01, 2012 | Emerson Televison & Video
My printer wont turn on , and i need it right now!
Please follow the instructions given below:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
Please try to print the self test
From Jeethu
Sep 15, 2010 | Office Equipment & Supplies
How do i reboot my 3301avr
Page 55
1 Switch off the unit and remove the AC cord from the wall
outlet. (for North America model)
Switch off the unit using the main unit‘s power switch. (for
multiple voltage model)
2 Hold the following AUTO button and PCM button, and plug
the AC cord into the outlet. (for North America model)
Hold the following AUTO button and PCM button, and turn
the main unit‘s power switch on. (for multiple voltage model)
3 Check that the entire display is flashing with an interval of
about 1 second, and release your fingers from the 2 buttons
and the microprocessor will be initialized.
Aug 05, 2010 | Denon AVR-2807 Receiver
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
I keep the ac adaper in but the charger doesnt
you can see the problem if the battery in not charging or not loading some current. you can do this by unplugging the adapter on the outlet. if the unit turned off then the battery is defective. replace it. now if the problem is the adapter, you can see by removing the battery then plug the adapter to the unit and in the outlet. if the unit didn't turn on, the the adapter is defective. replace it.
Apr 10, 2010 | Acer Aspire 6930-6771 Laptop
My brandnew Pioneer PDP-5020FD won't turn on.
Check page 9 of this document:
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/PDP-5020FD_OperatingInstructions0610.pdf
You will see that there is a power button on the bottom right corner of the back of the unit (item 25). Turn the unit on using that first.
Mar 17, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Power supply gone bad
Canon 9080C is a very good scanner, so dont dump it.
Yes all power supply units have a fuse. Check if it is okay. You can source scanner power supply board from the market, if you can handle it or it is easy to call Canon support and get it fixed.
Oct 11, 2006 | Canon DR-9080C Path-Through Scanner
Sovereign ARP-900E Air Conditioner Logo
81 people viewed this question
Top Sovereign Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
