Question about Canon Office Equipment & Supplies
I have a new Pixma printer. I got some paper jammed in the printer. After I removed the paper and pressed OK, I still get the error message "Rear cover The paper is jammed. Clear the paper and press OK"
  • Canon Master
  • 17,130 Answers
Make sure all the paper bits are taken off , now to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Posted on Sep 29, 2010
SOURCE: Clear Paper Jam error -- but there is no paper jam!
I have the same problem. Answer? PUt the piece of junk in the trash and never, never buy brother products again. I called Brother and they had a refurb for more than what it cost me originally!!!!!
Posted on Sep 09, 2008
  • 99 Answers
SOURCE: Message reads: the paper is jammed clear the paper and press OK
Even if a small piece of paper stuck inside the printer you ll get this msg.  So what you have to do is if you have a Air blower or vaccum cleaner blow air inside the printer,  If any piece of paper is stuck inside it will come out and you won't get that msg again.  Try this and sure it will work...!
Posted on Mar 18, 2009
samadhan_law
  • 54 Answers
SOURCE: canon pixma MP620 paper jam
i think u r roller of the pixma is getting hard so loose it means scroll it by u r hands for one or two times and then try
Posted on Jul 25, 2009
davedstone
  • 11 Answers
SOURCE: Paper Jam MX860
Double check as sometimes a small amount of paper will give this error message. If you are sure no paper is in the path/feeder, then unplug your printer from the ac supply for about 10mins (Logic reset) then plug back in and this should have this working again.
Posted on Sep 12, 2009
pineworks
  • 4041 Answers
SOURCE: MX860 error message reads: ''Rear cover - The
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
I continue to get error message 3 from my pixma
E3 is paper jam.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output)
is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service, because in most case when have a paper jam it's under withe rollers and printer must be disassembled.
Nov 24, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error, paper output slot
That means the sensor flag under the platen roller is broken, bent, or jammed in the up position. Hard to see and must be taken apart to repair.
Aug 07, 2009 | Canon PIXMA MP610 InkJet Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Apr 16, 2007 | Canon PIXMA MP780 All-In-One InkJet...
118 people viewed this question
old marine
old marine
