Question about JVC GM-V42 42 in. Plasma Television
Have a JVC GM-V42UG plasma monitor. The picture went off, and the red diagnostic lights came on. Top light flashes, middle and lower lights are solid. I already tried the "clean the vents" thing. The manual does not seem to address this specific configuration of diagnostic lights (top flashing, other two solid). Thanks! lt.john.ash@gmail.com
  • lt_john_ash Sep 29, 2010
    Thanks for your help. I'd hoped it would indicate something customer-fixable, but it is assuring to know that I am not calling a repairman for something that I could easily have done myself.
  • JVC Master
  • 11,800 Answers
This signals a hardware fault - more precisely it signals the fact that the power source is in protected mode because there's a short on one of its outputs.
To find out which actual part is the one that failed you must open the tv and test the power source with a voltmeter - the output which has a voltage much lower than the rated one (or even 0) is the one that powers the faulty part, follow it and test all the components.
Posted on Sep 29, 2010
POWER IS ON, NO PICTURE, SOUND OK
you need to check ur picture ICU. OR picture board
Nov 13, 2013 | JVC GM-V42UG 42 in. Plasma EDTV
Power on, no picture
check your input.... could be on hdmi or something with no signal... push every button on that remote and see if any of them actually get a menu or something to come up.... backlight could be off or just bad.
My JVC Plasma GM-V42UG was displaying the self-diagnostic light pattern of blinking/red/red, now it will not power up at all. Any suggestions?
It is impossible to say without checking several components and running some tests. It is most likely a problem on the power supply module although it is possible that it could be the y-main, x-main, and y-drive modules. I would definatley let a tech take a look at it and give you an estimate. A lot of times there will be capacitors that will go bad on the power supply module that can be replaced that is fairly inexpensive. You can inspect the power supply yourself for bad caps if you want. The caps will be mushroomed or domed on top rather flat. You can google electrolytic capacitor if you are unsure what they look like.
Jul 29, 2010 | Televison & Video
I have a 6yr old GM-V42UB 42in Plasma monitor. Has been acting up and then picture went away totally, All 3 self diagnosis light in top left are one with only the top one blinking. Any idea what this...
the manual just states to call your local jvc dealer/repairman and tell him what lights are flashing and he can tell you the meaning of the code
it does not list the meaning of what you are describing just the meaning if the top and bottom flash while the middle is solid.
so dont be shy give someone a call even jvc but youll be better off with someone local
Aug 03, 2009 | Televison & Video
Black Screen
i can fix it for 200.00 dollars u pay shipping or local delivery available.
Jan 31, 2009 | JVC GM-V42UG 42 in. Plasma EDTV
Need capacitor values on a Samsung Y-sustain PCB
That value is 3300000pF or 3.3uF (335) with 5% (K) and 250 volts ratings.
Nov 12, 2008 | JVC GM-V42UG 42 in. Plasma EDTV
No picture
Power supply, or main drive board are the two most common problems in many of these sets.
You would be best to send the set to the authorized service rep. He will be able to swap out the boards for new ones to find the bad boards. Then he would be able to adjust the set with the new boards, and it would be fixed.
Get an estimate before agreeing to service the set. These sets can be very expensive to repair.
Jerry G.
Feb 18, 2008 | JVC GM-V42 42 in. Plasma Television
No picture
That indicates an abnormal temperature rise in the power supply. These plasma TVs are board replacement repair only. The power supply board seems most likely would have to be replaced. I hope you have warranty coverage. It could get quite expensive to fix.
C-Dog
Jan 19, 2008 | JVC GM-V42UG 42 in. Plasma EDTV
Help please
call tech ..suggest CTRL board.
Mar 05, 2007 | JVC GM-V42UG 42 in. Plasma EDTV
Plasma DEAD?-please help
the green edges you desrcibe suggest a low HT supply from the power supply, and now its likley the power supply has failed completely and will need to be replaced
JVC GM-V42 42 in. Plasma Television Logo
162 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
