Question about Car Audio & Video
Wiring which is positive speaker wire for pt cruiser
    Problem Solver:
  • 3 Answers
Hi im new to this forum but i did a little research and this is what It should be (according to Chrysler)
Left Rear
BR/LB -
BR/YL +
Right Rear
DB/BK -
DB/WT +
BR=Brown
LB=Light Blue
YL=Yellow
DB=Dark Blue
BK=Black
WT=White
Posted on May 24, 2008
Chrysler pt cruiser power seat stuck in the up position
Most common issue is bad switch, but possible bad circuit breaker. Test for power at motor. If none, test for power going to switch. If none, either bad fuse/breaker or wiring fault.
Dec 19, 2014 | 2006 Chrysler PT Cruiser
I just bought a DEH2400UB car stereo to replace factory stereo in a 2001 PT Cruiser. I went to Best Buy and got the wire harness kit. Wire colors are not mactching up and I need help connecting to the...
If you bought a Pioneer receiver, you should know what its connections are. Adapter harnesses sometimes do not have the same color wires, BUT the connections are correct. In the 2001 PT Cruiser, the LF speaker wires are DK GRN (+) and RED/BRN (-). The RF speaker wires are VIO/DK GRN (+) and DK BLU/RED (-). The LR speaker wires are BRN/YEL (+) and BRN/LT BLU (-). The RR speaker wires are DK BLU/WHT (+) and DK BLU/BLK (-). A RED/WHT wire supplies power to the radio when the ignition is on and a PNK wire is a fused B+ input which is always hot. An ORG wire provides panel illunination and a BLK/YEL wire from the headlamp switch prevents the panell illumination from turning on unless the parking and/or headlamps are on
Dec 11, 2012 | Pioneer Car Audio & Video
Need to install remote starter and need wiring diagram for 2007 PT Cruiser
Hi drgghenso. Here is the starting system wiring schematic for a 2007 PT cruiser. Good luck with your installation!
Sep 28, 2011 | 2007 Chrysler PT Cruiser Touring Hatchback
Need a wiring diagram for 2001 pt cruiser
i have wiring digrams for 2001 PT Cruiser from Mitchell On Demand. Just need to know which specific part needed diagram for.
for example here is charging system for 2001 PT Cruiser
Oct 09, 2010 | 2001 Chrysler PT Cruiser
Chrysler radio wiring xm pt cruiser
Type Chrysler PT Cruiser ACC Manual Utility on the Net and look for Manual instruction
Sep 22, 2010 | Car Audio & Video
Were i the crankshaft position sensor located o a 2005 pt cruiser
near the oil filter.. above it...under exhaust manifold one small bolt holds it on. If the is a no start condition look for frayed wiring near crank sensor..... it has a harness that hangs too low on some of those. & rubs on cv shaft
Sep 14, 2010 | 2005 Chrysler PT Cruiser
Crankshaft position sensor replacement 2005 pt cruiser
it helps if you can lift or jack up the vehicle. be sure & use jack stands. it should be above oil filter on engine block under exhaust manifold. look for a sensor with one bolt holding it on. also check for frayed wires rubbing on cv shaft. sometimes all they need is fix one frayed wire
Sep 12, 2010 | 2005 Chrysler PT Cruiser
Need to know where the crank shat sensor s located on a 2003 pt crusier
Follow your plug wires to your coil packs. Your coil packs are attached to the ignition module. There will two wires running form ignition module right to the crankshaft position sensor which should be in the engine block
Aug 07, 2010 | 2003 Chrysler PT Cruiser
I hace 02 pt cruiser. while in reverse engine shut down when foot is taken of gas
you might have some wire toughing the ground rabbing when put it in reverse the eng shiftting causing wires to stretch and might touching ground or hot wire
Jul 20, 2009 | 2002 Chrysler PT Cruiser
Have a 03 pt cruiser with a trouble code P0302, stubbles bad and smells rich.
The P0302 Code points to a misfire detected on the # 2 cylinder. If its stumbling, I would first suspect the plug or wire is bad. I believe the ignition coil on that vehicle is a single coil pack with four terminals, so if only the P0302 code is coming up I would start with the plug and wire. May be time to do a tune up and just replace all the splugs and spark plug wires.
Dec 28, 2008 | 2002 Chrysler PT Cruiser
Car Audio & Video Logo
132 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
