I cannot install my printer, i have no driver
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Nov 14, 2011 | Canon PIXMA Office Equipment & Supplies
I dont have installer driver hp 695c
You can download a driver from the manufacturers website which is located at www.hp.com. Click on support and then download drivers/software. Enter the model number of your printer and follow the prompts to download and install the drivers. Do not connect your printer to your pc until the drivers and/or software is installed.
Jul 06, 2011 | HP DeskJet 695c InkJet Printer
The driver will not install
Instead of allowing the driver to install automatically when you plug in the printer, find the actual driver from the web, download it, and install it. Some companies include printer instillation in their drivers but some don't. If you still need to install the printer after installing the driver, follow these steps:
1. Click Start, click Control Panel, click Printers and Other Hardware, and then click Printers and Faxes.
2. Double-click Add Printer to start the Add Printer Wizard, and then click Next.
3. Click Local printer, clear the Automatically detect and install check box, and then click Next.
4. Click next.
5. Click Have Disk and find the drivers you just installed.
6. Click next until the setup wizard is complete.
7. Make sure to print a test page. If it works you're all good, if it doesn't try making sure you're using the right drivers and come back here if you need additional help.
You can find the drivers for your printer here:
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-D92-Printer/Drivers-Support;jsessionid=42CB17292574985A9FCC0A1D32049747.acc6-new
Apr 10, 2011 | Epson Stylus D92 InkJet Photo Printer
My printer not working with OS Windows 7
Remove all existing printer installations (delete printer instance from installed printers list). Depending on Windows 7 version, download the Vista x64 or Vista 32 drivers from: Select software and drivers.
Download the Print Driver Package, not the Plug and Play Package.
Ensure that the printer USB is NOT CONNECTED. Run the driver installation program, making note of the folder to which it installs the files.
Plug in printer USB Windows 7 will detect the printer but will prompt that the printer was not installed successfully. Do not attempt searching for drivers at this point.
Go to “Devices and Printers” , there you will find the HP 1020 newly installed. Right click on it, and select properties.
Click General tab, click “Make changes”, find again "properties" and "Update driver".
Click update drivers, then select “Browse my computer” and navigate to the driver installation folder that you have previously written down. Click OK to install drivers.
Jul 13, 2010 | HP LaserJet 1020 Printer
Driver installed automaticaly in w7 but doesnt print
1st You should download proper Printer Driver. sometime windows don't install proper Driver Here you can download Driver Epson LX Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager then Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
May 07, 2010 | Epson LX-300+ II Matrix Printer
I cant install my driver! how do will i install my driver?
1st You download Printer Driver. Canon PIXMA Printer Driver After this install the Printer driver in the system.
  1. Go to the control panel
  2. Click on the System Icon
  3. Click on the Hardware Tab
  4. Click on the Device Manager then
  5. Select the Unknown Device or printer device where yellow Question Marks sign on it.
  6. Right click on it and uninstall it.
  7. After this go to the top of the device manager and click on scan for hardware changes.
  8. Driver installation Wizard start.
  9. Brows Your Driver from the Hard Disk and click on next.
  10. Driver will be install.
Apr 30, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I lost my install cd and i cant install the printer lexmark x1270. already downloaded and installed the driver for it but still it doesnt work
1st You download Printer Driver. Lexmark Printer Driver After this install the Printer driver in the system.
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or printer device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
Apr 20, 2010 | Lexmark X1270 All-In-One InkJet Printer
Epson r300 cd printing problems
1st You download Printer Driver. EPSON Printer Driver After this install the Printer driver in the system.
Apr 04, 2010 | Epson Stylus Photo R300 InkJet Printer
Brother HL 2140 printer very slow printing.
It sounds like you haven't completely removed the old print driver. To do so, you must take the following steps:
  1. Open Printers by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then clicking Printers.
  2. Right-click the printer that you want to remove, and then click Delete.
    If you can't delete the printer, right-click it again, click Run as administrator, and then click Delete. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Another way or removing the printer driver is this:
1. Delete the printer from control panel -> printers
2. Open Services.msc and stop and start the Print Spooler service
3. Open Print Management(Open command prompt, type in printmanagement.msc or type print management in to the start menu search box)
4. In Custom Filters -> All Drivers right click the printer driver you want to remove and select Remove Driver Package
5. Install new printer driver.
Now that you've removed the printer driver, you can go ahead and manually install the new printer driver.
To manually install you must follow the prompts carefully.
Follow the instructions in this link:
http://www.vista4beginners.com/How-to-install-local-printer
At the install the printer driver section, choose have disk and locate the printer driver that you want to be associated with this printer you are installing.
This should solve your problem.
Mar 24, 2010 | Brother HL 2140 Laser Printer
Need to install printer and can not locate install disk
Go to the website of the printer manufacturer. Click on DRIVER DOWNLOADS. Download the correct driver for the printer you want to install. Save the driver on your computer's desktop. In the Windows® control panel, click on the install drivers icon. Drag the downloaded driver into the HAVE DISK data field. Follow the instructions for installing a driver in Windows®.
Sep 27, 2009 | Epson Stylus CX6000 All-In-One InkJet...
18 people viewed this question
k24674
jasbo
jasbo
