Question about Kitchen Ranges
FRONT RIGHT BURNER DOESNT WORK FRIGIDAIRE PRO SERIES RANGE MODEL CPLEF398CCD (OR PLEF398CCD)
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
Posted on Mar 02, 2008
  • 184 Answers
SOURCE: No power on right hand side burners
WHEN THE SURFACE SWITCHES ARE IN A ROW ON THE CONSOLE, THEY ARE USUALLY WIRED IN PARALLEL FOR THE INPUT VOLTAGES(RED AND BLACK WIRES ATTACHED TO EACH OTHER). IF THERE IS A BURN OUT OF ONE OF THE WIRES, IT WILL AFFECT THE OTHER SWITCH INPUTS DOWN THE LINE.
TAKE OFF THE BACK PANEL OF THE CONSOLE AFTER UNPLUGGING IT AND CHECK FOR VISIBLE SIGNS OF WIRES BURNT. REPAIR OR REPLACE IF NEEDED. SOMETIMES, THEY WILL DAMAGE THE TERMINAL OF THE SWITCH THEY ARE ATTACHED TO. IF THIS IS THE CASE, THE SWITCH WILL ALSO HAVE TO BE REPLACED.
Posted on Apr 04, 2008
SOURCE: burner on range will not turn off
I am also having turn off problem on smaller burner of dual burner glass stove as of 8/2/08. It remains on high even when know is in off position.
Posted on Aug 03, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
SOURCE: Front burner won't shut off. Have to close at breaker.
For $9.99 I will be glad to share the solution.
Posted on Jun 21, 2009
Fridgidaire stove clock not keeping correct time
Clock logic can not be changed replace the whole board
just lets you change the time will not let you slow it or speed up
Nov 14, 2013 | Frigidaire FGGF3054KF Gallery Series...
Frigidaire electrolux model plef398ccd
You will need to replace the control board. Here is he part to order.
All parts come with a 365 day, any part, any reason return policy.
Apr 04, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
I've used you guys once before - right the first time so trying again for a different problem. I've got a Frigidaire glass-top electric range (model PLEF398CCD) and 2 of the four burners stay on...
Thanks for using Fixya once again we appriciate it!
The problem with your stove is going to be with the infinate switch(what ya are calling knob) for the burners that giving ya trouble are shorted and the contacts inside of it are welded so they permanantly are stuck on the HIGH setting. To repair that the switches for the affected burners would need to be replaced.
The part number for those switches is 316095503 they could be purchased at your local appliance partstore or online at;
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Oct 02, 2011 | Kitchen Ranges
Frigidaire professional series gas stove does not light. When handle is turned the "clicking" sound happens, with the smell of gas but no flame. what could be problem? 3 other burners work...
A few months ago I lost one igniter on the left front burner. It clicks and gas flows but wont ignite.Now when I turn on the left back burner, the gas still flows but I hear clicking on the right side, not from that burner. It wont light either.
Dec 17, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Frgidaire Pro series gas range not lighting on one burner
there is probably some residue keeping it from sparking. look at 1 of the other burners and take mental note from where the spark is coming from. then spray just a little oven cleaner on and around the one not working. naturally take the metal grid off first.. let set for about 15 min. then wipe away the residue gently as not to damage the igniter electrode.. also there is a possibility the wire leading to the igniter fell off causing this problem.. do the explained first. good luck...
Nov 15, 2009 | Frigidaire PLGFZ397G Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
