Question about Safe T Alert Lp Propane Gas Alarm Rv Trailer
My 2000 Fleetwood Pace Arrow was broken into and among other things, the Safe T Alert Propane Alarm was taken. There were 3 wires left cut and dangling, one black, one solid red and one red with a white stripe. After using a volt tester, I found the solid red was hot when the master battery switch was on. The red with white was hot when the aux. battery swithc was on. Here is the quesiton, the new propane detector from Safe T Alert only has one black and one red wire. Should I splice the red and red/white wire together so the detector is on while both or either battery bank is on? I don't think this would cause a problem but, I wanted to confirm that this wouldn't create an issue for the detector or other electical systems.
  • 10865 Answers
SOURCE: I have a Class C motorhome. The unit is in storage
hi chuck. the source of the carbon monoxide is outside of your unit. for example other engines running near by sending fumes into your unit and setting off your alarm
Posted on Jun 25, 2009
  • 127 Answers
SOURCE: We have a 2007 Palamino
Is this a six way plug (six round holes)? If there are six wires coming from the trailer, then the color code should be as follows:
White - Ground
Brown - Tail Lights
Yellow - Left Turn
Red - Stop
Green - Right Turn
Blue - Auxiliary Circuit (Battery Charge, Electric Brakes, etc...)
If you open the plug up that was cut, it is labeled as to which goes where.
TM = Tail Lights
RT = Right Turn
LT = Left Turn
S = Stop
G = Ground
Center = Auxiliary
Posted on Jul 04, 2009
sprinklerfit
SOURCE: camper electrical wiring and propane lines dont work
you need to find the propane lines and where ever you have a joint you need to put "snoop" on it. which is basicly soap and water sorry my spelling sucks. anyway you do this with the propane on and whereever you have bubbles you have troubles. you can even check your lines with it. Now yoiur electrical woes can be fixed by tracing your wiring and finding out where you have a short this is when two wires are either touching eachother both of these problems take time and they take some experience. If you mess this up you could blow yourself up. Let me know what you are going to do. I'm worried for you
edwar355
  • 71 Answers
SOURCE: My refrigerator and stove will not run on propane.
theres a transfer switch that may have went bad.......also (I know you've done this) but check all your valves to make sure there open
Posted on Feb 14, 2010
  • 3 Answers
SOURCE: Our propane alarm sounded due
It is operating as designed. When there is low voltage it thinks there is a problem and lets you know it. The only way I know to disable the alarm is to disconnect it, depending on how it is wired.
Posted on Aug 29, 2010
How to id 74 pace arrow motor
Look at the motor builder not at the RV section, Louis
Aug 24, 2016 | RVs
1983 Pace Arrow by Fleetwood. Where can I get a wiring diagram?
contact Fleetwood tech support they will send you a PDF file of it
Dec 17, 2015 | RVs
Need a Wiring Diagram for a Radiator Condenser Fan which shows how to locate the Relay and Switch for a 1996 Fleetwood Pace Arrow Vision RV P30
I would call fleetwood out of nappannee Indiana a lot of times they use a special wiring using the A.C systems they install
Sep 18, 2012 | Cars & Trucks
Where do i find a manual for a 97 37ft pace arrow? or a least the specs for gas and holding tanks?
The only place you are likely to find a manual for a Pace Arrow is from the manufacter. Although ebay does sometimes have Pace Arrow manuals for sell on it.
Jul 01, 2011 | Ford F-450 Cars & Trucks
Our propane alarm sounded due to the camper battery dying. Wee turned off the propane....is there a way to disable the alarm?
Aug 29, 2010 | Safe T Alert Lp Propane Gas Alarm Rv ...
I bought a used 1984 pace arrow on a chevy chassic, while checking out the wiring I have found so many wires attached to the fuse box and other wires, I am trying to find a wiring diagram for both the...
you will have to contact pace arrow if still in business for the 120 volt wireing.they are all pretty much the same in similar years motor home so generic rv how to manuel would be ok.contact chevrolet for a cab and chassis manuel. as a side note, on the 120 volt system the black wire is not a ground.it is the hot wire.the white wire is nutral[ground] the 12 volt stuff is color coded like a 1984 chevy
Jun 07, 2010 | 1989 Cadillac Fleetwood
My refrigerator and stove will not run on propane. I have 3/4 tank of propane and my RV is level. Any ideas?
Feb 13, 2010 | Safe T Alert Lp Propane Gas Alarm Rv ...
Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Mar 31, 2009 | Water Heaters
Safe T Alert Lp Propane Gas Alarm Rv  Trailer Logo
99 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
