Electric Heater Broke down after 2 weeks..air still comes out but no heat..cant find it worth fixing..minor or major problem? Thanks Marie
If the heating element may be failure, or heating fuse may be gone . Pl. check and tell me or send me Photo of heater.
Posted on May 26, 2008
I have a 2003 Dodge Stratus Coupe R/T. Just got it inspected and it failed. Check engine light is on and the codes it failed for are P0136, P0141 and P0456. Pep Boys told me I have to take it to the...
You have to realize that vehicle is15 years old and probably worth peanuts. if you repair it then a few weeks later it breaks down again you have probably wasted your money. i feel to repair it you will pay close to a thousand dollars then you don't know if it will pass a safety next year
I would scrap it and get a good one. Just to go to a dealer for a check up will cost over a hundred dollars.
Dec 18, 2017 | Cars & Trucks
I have a 1992 RENAULT 19 TXE CHAMADE that over heats and only cools down if i turn on the heater inside the car. If the heater is turned off, the car over heats, if you turn the heater on it cools down to...
to know the solution of the problem you need the original company repair and service manual with its help you can locate the problem and can fix your self and the manual you can can eaasily from the given link
Oct 28, 2017 | Renault Sport Cars & Trucks
No heat 2006 pontiac torrent awd
your air damper or diverter may not be working.this is basically a mechanism that opens a flap by your heater core to control the amount of hot air that comes out.There is a rod that this flapper pivots on and if this rod is broken or the motor that operates it is not working you will either have heat all the time or no heat at all depending on which position it broke at.I know because my torrent has the same problem.To fix my problem they have to remove the dashboard to access the heater core which amounts to major $$$. I hope your problem is an easier fix. good luck
Mar 14, 2010 | 2006 Pontiac Torrent
I can smell coolant when heater is on and coolant light is on
Sounds like the heater core is leaking. Fill up the coolant and look under the carpet on the passenger side and see if there is not coolant there. IF it is a really minor leak you may be able to use a radiator fix, but do not buy something cheap and follow the directions. If one application does not seal it up, replace the heater core. It is not worth overheating the motor to try more of the sealer; it can clog the coolant passageways in the motor.
Hope this helps
Jan 23, 2010 | 2001 Saturn SL
Climate control on a 98 Pontiac Bonneville
if the compressor suction line is getting cold and sweating and the line going out to condensor is hot - the compressor is working - the electric door to cut off heat is stuck or motor coupling could be broke - this unit under the dash can be hard to get to - i have installed a valve in heater hose to cut off hot water in summer on older cars - cheap fix - unless you want to take out dash
Sep 11, 2009 | Heating & Cooling
I have a 2000 ford windstar no heat still
My 99 windstar did this too. It was the blend door that the actuator motor goes into was broke. When you pull the actuator out look into the hole and see if you see a d shape piece coming out of the box if it is not d shape it is broke check out this site great photos
Feb 27, 2009 | 2000 Ford Windstar
I purchased a Friedrich PDH15KS BTU Cooling, 17,000 BTU Heating, 9.3 EER PTAC Air Conditioner With Heat Pump and 5.0 KW Backup Electric October of was installed in November and ran...
The Warranty will be expired. Sounds like the contactor for the heater is wearing. Obviously a guess, but, "rattling" sounds like a bad cintactor to me. If thats the case, im guessing $100 diagnostic, $75 for the contactor, ISH...Best Wishes!!
May 23, 2017 | Friedrich Heating & Cooling
Les, it sounds like your blend door actuator has failed, it is a small vacuum operated diaphram up under the dash that controls a flapper that switches between the cool air and heated air. Good news is that it is an inexpensive part, bad news is pulling the dash out to get to it.
Oct 02, 2008 | 2001 GMC Jimmy
There is only hot air coming out of the heating system.Is there something serious wrong or can this be fixed?
I once owned a yugo back in the 80s, and the only thing good about that car was that it was equipped with a rear window defroster, so when it broke down in cold weather, which was frequently, my hands stayed toasty warm while pushing it. As for the hot air problem, it is probally the water valve that leads to the heater core. From my recollection, there is a wire cable coming from the temperature knob from the dash which is routed to the engine compartment to the water valve. When the temp knob is set to heat, it moves the cable which in turn opens the valve, thus letting hot water from the engine block to the heater core. The cable could be broken or just disconected. Or, the valve itself may need to be replaced, which is a fairly simple job, The difficult task is finding a new replacement part. I would suggest not installing a used or junkyard part as they are most likely rusted and non functional. In conclulsion, this is not a serious problem, but only a minor inconvenience during the warmer months.
Sep 10, 2008 | Yugo Hatchback Cars & Trucks
Heating & Cooling Logo
91 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
