Question about Car Audio & Video
2007 pt cruiser
I'm trining to hook up after market speakers to a pt cruiser 2007 , which is positive and negative.
    Problem Solver:
  • 3 Answers
Hi i did a little research and this is what It should be (according to Chrysler)
Left Rear
BR/LB -
BR/YL +
Right Rear
DB/BK -
DB/WT +
BR=Brown
LB=Light Blue
YL=Yellow
DB=Dark Blue
BK=Black
WT=White
Posted on May 25, 2008
Our 2007 pt cruiser had computer replaced, and now the car will not shift gears, we check tran fluid optimal level, turn key back and forth several times until it says done. then drives normally.why?
On new cars there are several ways to reset the computer. I got a truck I have to turn key on and hit gas 5 times fast and 30 seconds, and then start it. *What always works is to disconnect battery- Negative(black first) then the positive (red side)-(do not let touch sides of metal firewalls). after 30 + seconds hook it back up and it should reset the computer.
Aug 27, 2017 | Cars & Trucks
What color is the neg and pos wires to the passanger side speaker in a 99 chevy blazer
Hello, I am assuming it is the rear passenger speaker. Please refer to the list below for the wiring of your aftermarket speaker.
Radio Constant 12v+ Wire: Orange
Radio Switched 12v+ Wire: Dark Green
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Stereo Dimmer Wire: Violet/White
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Feb 13, 2013 | 1999 Chevrolet Blazer
Need to know which fuse to pull in order to disable the fuel pump so I can change an injector on a 2007 PT Cruiser 2.4L I power dist box lid is not labeled and there is no owners manual
It actually might be better to just disconnect the negative side of the battery and then bleed the pressure off manually, that is how we do it at my shop.
May 24, 2011 | 2007 Chrysler PT Cruiser Touring Hatchback
My wiring plug to the back of the radio was cut on my 1990 4runne
fun fun fun.
1990 Toyota 4Runner Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Yellow or Blue/Black
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Purple
Right Front Speaker Negative Wire (-): Blue
Car Audio Rear Speakers Size: 5 1/4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Jul 31, 2010 | 1990 Toyota 4Runner
Battery charge Diesel PT Cruiser
You can connect the - or negative to the negative on the battery or whereever it will reach on the engine or body. The engine and battery are preferable. Just be sure it makes good contact, bare shiny metal is best, a quick rub with a file or sandpaper before you hook up is a good idea. Watch the guage on the charger as youwiggle the charger cables to see if it moves higher. If it does, clean up your contact points. Hope this helps.
Feb 07, 2010 | 2005 Chrysler PT Cruiser
Need a wiring diagram for the stock stereo system in order to install after market unit
2007 Saturn Vue Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Light N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Good luck and Happy New years.
Jan 04, 2010 | 2007 Saturn VUE FWD 4
Witch wires do i use to hook up an after market cd player in my 2000 mazda millenia
Here is the diagram in words as found at
http://www.modifiedlife.com/2001-mazda-millenia-car-stereo-wiring-diagram/
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Illumination Wire: Green/White
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Pink
Right Front Speaker Negative Wire (-): Purple
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Green
Left Rear Speaker Negative Wire (-): Yellow/Green
Right Rear Speaker Positive Wire (+): Green/Black
Right Rear Speaker Negative Wire (-): Green/Orange
Jul 16, 2009 | 2001 Mazda Millenia
Pt cruiser electrical
It could be your alternator. If the battery light is on thats usualy what thats a sign of and areason it may still run and not accelarate is your battery has enough juice to start it, but not to keep it running. If this is the case try hooking jumper cables to it and seeing if you can throttle it up with them hooked up.
Aug 21, 2008 | 2003 Chrysler PT Cruiser
Car Audio & Video Logo
114 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
