Question about Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum
How do u open up the compartment to empty the trash
  • 3 Answers
I couldn't figure that out either...since I misplaced the owner's manual...Anyway, there is a little gray colored knob at the top of the "collection" canister...and simply press that button and it disassembles that canister from the rest of the upright and then you are able to empty that trash contained therein.
Posted on Oct 04, 2010
So I just got my shop vac second hand and it has no manual and no basic instructions were given either. Does it actually need a bag when using it? I feel like something may be broken or missing....
Shop cacs are multiple purpose dry/wet intake so typically you don't need a bag. You just open the tank and empty it like a big trash can. They will have a large filter In the tank that needs to be cleaned/replaced.
Oct 16, 2015 | Shop Vac Vacuums
How do I empty the tank instructions do not say
Looks like you have a bagless vacuum. The other kind have a tank. The tank can usually be removed by pressing a lever or switch somewhere on the top area of the tank.
When you get the tank off, it will come apart easily. Try to remove the top of the tank. Then you can dump it out into the trash. Watch how you open and removed the tank so you can put it back together again.
Hopr this helps.
Feb 02, 2015 | Vacuums
Why does robot roomba 530 repeatedly stop and say to clean brushes
I think it's telling you to flip it over, open up the brush compartment, take the brushes out, remove everything wrapped around them, replace them and close it up. I suspect that your brushes are wrapped up with something.
Next open up the filter compartment, dump it into the trash, pop or slide out the filter and bang it into the trash can. Give it a quick rinse in the sink to wash off the fine dust still on the filter. Let it dry and insert it back into the filter compartment.
May 16, 2014 | iRobot Roomba 530 Robotic Vacuum
Our Dyson dc33 started making an awful noise and smoking. We've had it for a couple years. We cleaned out the hair and debris from the roller and the dirt compartment is emptied. Is there a way we can...
Fix it yourself? Perhaps. You need to open up the compartment where the Motor Drive is located. Inside you may find a Motor Belt that has gone bad and needs replacement. The manufacturer has replacement belts. They are easy to put on...so go for it.
Dec 18, 2013 | Vacuums
The clear garbage canister will no longer open to empty trash.
I'm sorry to hear you're having difficulties with your DC18. If the bin-base won't release when you press the red trigger, please get in touch with us directly so we can assist in resolving this issue for you as quickly as possible. You can call us free on 1866MYDYSON - we'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Jul 19, 2011 | Dyson Slim DC18 All Floors HEPA Bagless...
How do you empty the dirt out of it
The plastic dirt holder should have a lever that opens the canister.Should come right out with a slight pull.empty contents into the trash.
Oct 21, 2010 | Dirt Devil Easy Lite Quick Vacuum
How do you empty the bag?
Little gray colored knob at the top of the canister housing and you press that and it seperates the canister from the rest of the upright and then you can go empty the trash collected therein.
Oct 03, 2010 | Euro-Pro NV22 Shark Navigator Bagless...
How do I open the dirt cannister on a dyson animal (purple) so I can empty the dirt out?
This is fairly easy. Click on the button at the top of the hand above the cannister. It's a purple button and the handle faces the front and says Dyson on it. This separate the cannister from the body.
Next, hold the now full cannister above a trash can and click on the red button which was below the purple button (but hidden when it was attached).
May 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I can not find how to get the canister apart to empty the dirt.
From the bottom of your machine going upwards past the handle that is on the canister portion of this vacuum, you will see that the top of that canister had a depression where you should be able to put your fingers in, and gently pull that lid back, opening the vacuum bag compartment. According to the manual, simply pull that back, exposing the bag. To remove the bag, pull the cardboard plate on the top of the bag, out towards the no open face. Throw away your old bag, and take your new bag, fold down the paper sides of the bag, then slide the new bag into the track completely. Close your lid, and you are done.
While you have this compartment open, it's a good idea to check your filter that sits below the paper bag.
Part numbers
Paper Bag: SC-P11
Filter: SC-F2
I hope this helps you.
Jan 20, 2009 | Sanyo Transmax SC-180 Handheld Vacuum
I have acquired an old Regina Electrik Broom
Hi jmathe, Looking at the back (business side) of the vacumn: Underneath the white plastic dirt cup, please find a cast aluminum latch, that secures the part you will empty. To remove the white plastic part, turn the aluminum latch handle downward, and to your right, while you are holding on to the dirt cup with your left hand. I usually wear a dust mask, and empty the dirt into a small grocery bag, to tie shut, before placing it in the trash. To replace the dirt cup, turn the cast aluminum handle back to where it was before, handle pointing left. The more often you empty the cup, the longer your Regina Electrik Broom will last. Mine is forty-five years old. Allow the motor to cool, often, as well.
Jan 07, 2009 | Regina ElectrikBroom RG100 Vacuum
Euro-Pro NV22 Shark Navigator Bagless Upright Vacuum Logo
320 people viewed this question
Top Euro-Pro Vacuums Experts
 Tony C
Tony C
Level 1 Expert
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
