Question about Refrigerators
I want to fix handles on the doors. Can I remove the finger holds at the sides of the doors to access inside of the door fronts?
  • 17,130 Answers
You have not mentioned the model but you will have to open the inside lining of the tray holders , to remove to get access to the handle fitting screws, which can be removed to fix the new one.
Posted on Sep 29, 2010
Remove interior door panel 2002 Chevy tracker
No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Check out youtube video showing how to do it !
How To Remove Install Front Door Panel Suzuki XL 7
Jun 10, 2017 | Cars & Trucks
Passenger door can be opened from inside but not from outside...how too fix???
Remove the door lining and look inside by the lock. There is a linkage that has come adrift. To remove the door lining, remove handles, escutcheons, and arm rests. Using a wide blade screw driver gently pop the plastic rivets that hold the lining to the door.
Dec 02, 2015 | Cars & Trucks
Drivers side front door will not open from inside or outside even using the key
Sounds like the clips that hold the rods, that operate your inside/outside door handles have come loose. You will have to get the door panel off...but first...you'll have to get the door open. OK...where your inside door "lever" is located....there is a plastic cover behind that lever.....also, there might be a small plastic access cover... over the screw that holds on this larger cover in place. If so....pop the little access cover off and there will be a screw behind it. (keep in mind...this is behind the inside door lever you pull on to open the door) remove the screw...remove the cover...you should now be able to see where the rod has come loose. if you cant grab it with your fingers, get a pair of pliers and pull forward ( toward the front of the car) to open the door. Make sure the door lock is off also. You may find the clip that holds the rod to the lever is broken or the rod has just fallen out of the clip. Sometimes, you can wire the clip into place so it dosnt come loose again. At this point, you will want to remove the door panel....because the "outside door lever...rod...is also loose...in which case you will need access to the inside of the door to fix it. Just remember, you only want to this once...so while in there...fix it right....
Theroadisalover
Try to post back and let me know If I helped you solve your problem. It will help me with my rating....! Thanks
Jan 01, 2011 | 2001 Saturn L-Series
Broken door handle
Which door, front doors or slider. Front door handles are readily available at most auto parts stores. Pull off the inner door panel and access the inner 10 mm nuts which hold the handle to the door. Once the nuts are off pull the handle out from the outside and remove the actuator rod from the handle. Install the rod on the new handle and replace it in the door making sure the rod slides into its corresponding female connector in the door before attaching the nuts. Its a lot of tight finger work but you can do it with a little patience.
Aug 10, 2010 | 1995 Chevrolet Lumina Apv
Passenger front door does not open from outside, only from inside. Also, driver's side door has to be jiggled a bit to get that door to open from outside. The inside latch is loose. Just bought this car...
this is a common problem with VW door handles, but an easy fix!!! The door handle needs to be replaced as the fork that lifts the lock has broken off or cracked. Depending on the model it is easy to remove the door handle. spring off the Crome mld on the front and on the slam side of the door behind the rubber u will find a phillips screw. Under the crome mld is the other.
Good luck.
Jul 19, 2010 | 1996 Volkswagen Passat
1997 mercury villager passenger side mirror replacement guide. how do i do it? is there an easy access panel or does the whole door panel need to be removed
door panel must come off.
go here for villager help
http://groups.yahoo.com/group/villagerquest/
Section 01-05: Trim, Interior 1997 Villager Workshop Manual
REMOVAL AND INSTALLATION Trim Panel(s), Door
Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  1. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel.
  1. Pull the shop rag back and forth to release the window regulator handle clip.
  1. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  1. Remove the front door trim panel.
Installation
To install, reverse the removal procedure. Body Side
Removal
  1. Gently pry loose the body side door latch handle bezel and remove it.
  1. Slide a suitable tool behind each of the retainers and twist the tool to disengage the body side door trim panel from the body side door (24622).
Installation
To install, reverse the removal procedure. Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
Installation
  1. Install the front door watershield in the proper position and press firmly at the adhesive areas. If necessary, use additional adhesive to ensure an adequate seal.
  1. Install the Front Door Trim Panel . Refer to the installation procedure in this section.
May 22, 2010 | 1998 Mercury Villager
Removing/installing 2000 dodge grand caravan window glass
after u remove the bolts that hold it to the window regulator tip the window towards the front of the door and the top rear corner of the window should pop out and then u just lift hte window out,hope this helps
Sep 05, 2009 | 2004 Dodge Caravan
How to remove front passenger side interior door panel on 2005 pontiac wave (same as Chevy Aveo). Need to re-attach door handle. Screws that hold it on attach from the inside of the panel.
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Jun 10, 2009 | 2005 Chevrolet Aveo
Oven door handle (right side)came loose
If you put the door at a 45 degree angle on the hinges, it will lift right off. Then once on the ground, it should be easy to remove the screws of the inner panel and expose the screws that the door handle attaches to.
Mar 13, 2009 | Maytag MER5555Q Electric Kitchen Range
How do you remove inside door panel.
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Sep 17, 2008 | 2001 Chevrolet Tahoe
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
