Question about SNK Magnavox 42MF231D 42 in. Plasma TV
I have a sony trinitron flat picture 19 inch tv. i live near ocean environment. so there's salt air and also humidity. many tv's have come and gone. my tv's red light blinks too. so i know there something wrong. the tv will start i just have to keep turning it on and off and hope the picture will appear. what's the problem and should i fix it or just buy another tv? i'd rather stick to this one.
  • SNK Master
  • 17,130 Answers
Your case is a pure case of component deterioration with added salty moisture build up which corrodes and makes circuit joints weak. the fault will only keep increasing according to the damage. here are some tips to help;
http://www.fixya.com/support/r6055091-slow_start_up_circuit_cold_starting
Posted on Sep 29, 2010
I am living beside sea side. where humidity in the morning ranges from 63 to 79 and in the afternoon from 44 to 76 throughout the year. i have bought 15 in number LEDs sony bravia 50" for my operational...
I would suspect you have a power problem. Voltage too low or high can damage electronics very quickly. Voltage spikes also can fry TV's. Your power company can help. Monster makes a complete power solution with sophisticated filters and a power supply regulator that will keep power within specs but you will spend close to $ 1000 for this solution. I don't think Humidity is the culprit but corrosion due to salt is another matter. If salt is the culprit then you are out of luck unless you want to install the kind of air filtration system used for a shelter from Atomic Attack.
Using the KISS principal I would check the power first.
Sep 29, 2013 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
I have a 32" Sony Wega Flat Screen TV. Currently
Check out this article: http://www.ehow.com/how_8256946_fix-sony-32-trinitron-picture.html
It goes pretty in depth in how to troubleshoot problems with your Trinitron TV. Hope this helps.
Sep 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony trinitron model number kv32hs500 were is the
If you take the TV and lay it flat on its face, then you will be able to get the whole back cover off. Once the back cover is removed, and with the TV still on its face, there will be some a large circuit board sticking up in the air from what is normally the bottom of the TV. At this point you may want to tip the TV back onto its bottom (so the screen is showing again). Now, on the right side of the circuit board, near a couple things that look like large batteries sticking up, will be the two IC chips. They are about an inch long and maybe half an inch wide. They are only a couple inches from each other. Hope this helps you locate them.
Apr 10, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
My tv has sound but no picture. The screen is greenish in color.
SONY TRINITRON TV 32 INCH MOD# KV-32FS10 SER# 9006800 PICTURE INTERMITTENTLY BLANKS OUT AND COME RIGHT BACK NEVER LOOSE SOUND.
Feb 07, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Are they HD compatible? We recently upgraded our cable on our 32 inch Sony Trinitron Wega tv (bought it in 2004) and got the dvr/HD package but get no HD channels...help??
These units are not HD sets. So if you want HD sorry to say you will need a different TV. If you can live without the HD these TVs have a great picture thats as close to HD as a regular set gets.
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
SHORT PICTURE
it could be a setting in the picture menu it sounds like it is set to 4:3 there should be an adjustment in the picture menu on your set hope this helps regards Jim
Mar 31, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Picture is all different flashing colors
Maybe you put magnet near to your TV or something that can produce magnetism.... if not the deguassing system is not functioning anymore. .. bring your unit to near service in your place.
Apr 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron 32" TV will not come on and stand-by light blinks
It cant hurt to try...
While I was reading some other post about this problem, one guy said to try using a hairdryer on the right side of the TV1.gif for a few minutes to dry out humidity, becuse the trinitron has some kind of feature that causes it to 'protect itself' when too much humidity is in the air.
Hmmmmm sounded silly, but we had nothing to lose and tried it.
Lo and behold, our TV is back on.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv stopped working
HV problem. I'm sorry but there is a time for the TV dudes to come see everyone and this is your turn...accordianman
Oct 10, 2007 | Sony FD Trinitron WEGA KV-36FV300 36" TV
SNK Magnavox 42MF231D 42 in. Plasma TV Logo
49 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
