Question about Jet 3 Ultra Power Chair
New batteries @ wont hold a charge might have connected wrong do you have a diagram for battery hookup?
  • 692 Answers
If the batteries were wrong you would not get power at the joystick and you wouldn't be able to turn it on. If it is coming on and working then your problem is either a bad charger or a bad battery. If you charge the chair and the green light on the charger is on (indicting a full charge) unplug the charger and if you have a digital voltmeter put it on 200 v dc and plug the leads into the 2 outter pin holes of the charger port located under the front of the joystick you should be reading 25-27 volts after charging if less than that then either the charger didn't work or you have a bad battery or batteries. New ones sometimes can be bad. If you know of a friend or can borrow another charger try charging with it to see if it makes a difference Hope this helps
Posted on Sep 29, 2010
My car has stalled while driving before and after leaving the shop. When i get the battery charged and put it back in my car starts fine but stalls when the battery runs out of juice. Ive had my alternator...
What's the voltage at the battery with the car running ? Testing an not guessing is the way to do proper diagnostic's ! Battery light staying on , is there B+ voltage at the alternator connection's ? A new alternator won't make a bit of difference if no power to the alternator . Looking at a wiring diagram an testing the electrical circuit ,doing voltage drop testing , plus checking for DTC'S - diagnostic trouble code's . Some vehicle's charging systems are computer controlled . And looking at a wiring diagram i see your vehicles charging system is computer controlled . If you have done so already , take it to the dealer
Dec 10, 2017 | Cars & Trucks
Audi a4 quattro
don't think fuse diagram will help , is the battery in good condition , may not hold enough charge to turn over engine , try jump start if engine starts then get a new battery then check alternator charge rate as may be reason battery went
Jul 15, 2014 | 1999 Audi A4
I have take out my rx 8 battery to re charge it and when I replace it the engine won't turn over.
you either have'nt recharged as it isn't holding the charge ,or have it connected the wrong way round , which i doubt, have the battery tested for holding charge , if no good the get new battery and check the alternator charge rate as could be low and not charging battery
Jun 24, 2014 | Cars & Trucks
My contenintal wont hold a charge installed a new alternator and regulator where do i find the wires to check them
remove the positive battery connection and check continuity from the cable terminal to the output on the alternator. you can go to autozone.com to view wiring diagrams. register and enter your car. then select repair guides. also, has the battery been tested and found good?
Mar 23, 2010 | 1995 Lincoln Town Car
My 1995 seville battery wont hold a charge.on the
You may have a bad alternator... you can have it checked at any auto store for free... Also check your positive/negative wired connections...your connection to your positive cable that goes to your starter may need to be replaced, or your negative cable could be bad also.
Feb 17, 2010 | 1995 Cadillac Seville
Wont start
check for battery voltage at the charge post on the alternator and at the 2 wire connect with the key on .if you have it then its a bad alternator. if you have a belt spinning the alternator.
Feb 04, 2009 | 1990 Jeep Cherokee Limited
Santa fe wont start.
Clean & scrape battery connections well to assure good electrical contact. Charge battery fully on charger. When you get it started after this, make sure that car is charging battery , first by lights on panel, and then by external measuring device if necessary and available. Many new batteries come uncharged, so that may be your main problem. Costco is a good source of reasonable cost quality batteries, but you may have to charge them and they may not install. Walmart probably good also. Both places allow returns. Follow all safety warnings on battery hookup, as hydrogen explosions are very rare, but very bad when happening, prevented by keeping sparks caused by connecting AWAY from top of battery!
Nov 30, 2008 | 2001 Hyundai Santa Fe
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Oct 29, 2008 | HP Compaq Evo Notebook N600c
Charge is complete but wont go on wthout power connected
I am sorry to say this...but chances are that your battery has malfuntioned or simply can't hold a charge anymore. If you want to be 100% sure try the battery in another PSP...and if it works then there is eomthing wrong with your PSP (this second scenerio is highly unlikely). I recommecnd getting a new battery. Good luck!
Dec 14, 2007 | Sony PlayStation Portable (PSP) Console
Jet 3 Ultra Power Chair Logo
107 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
