WILL NOT AGITATE, SPIN OR DRAIN. WASHER FILLS WITH WATER, HOWEVER, WHEN AGITATOR CYCLE BEGINS, MOTOR HUMS AND BELT WILL NOT MOVE.
  • whybrandabar Sep 29, 2010
    Whirlpool Model LA7680XM
    Genius:
  • 1,044 Answers
Open the back cover and start the washing cycle. When the agitator cycle begins check if the motor rotates. If it does not and the humming sound comes there is problem is withe motor. Also check the tightness of the belt. Even if it is loose it does move but it is slippery movement unless it is completely loose. Anyway the problem is with your motor and the connecting bearing/pulley. You have to ask a technicians to help you out
Posted on Sep 29, 2010
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Washer agitates but will not
Possible fault in the timer unit as it fails to contact on the program set within . It will be good to have the contacts tigtened , use some degreasing spray to clean the contacts. make sure that the connections to the controller are tight.
If there is no result even after a cleaning it is possible that the timer controller unit is faulty and needs a replacement as it is not locking in unison with the program to the contacts.
replace with the same type, make sure that each connection is market and put in accordingly with a lot of attention and care not to misplace the leads.
Posted on Nov 05, 2010
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Washer keeps spinning. doesn't move to next cycle
It sounds like the agitator , air bell or transmission is failing. Since the unit spins the belt & motor is ok. I recommend removing & inspecting the agitator & air bell. If they are not stripped out then you have a transmission failure.
Or, start the washer at the beginning of a cycle set to the lowest water level. After the unit fills it should be agitating stop the washer. Open the lid & try moving the agitator, if the agitator will not move it is good & no need to remove for inspection. You have a bad transmission. If the agitator moves easily then we know that the agitator or air bell is stripped out & will need to be inspected for confirmation before replacing.
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Doesnot spin or agitate.
if you have the front panel off and you can see the motor is spinning the belt is turning then your transmission has failed.waring keep hands clear of all moving parts! transmission pn wh38x10002 for around $185 if mtr is not moving pn wh49x10040 for about $240 depending on what you need and how old your washer is it might be time for a new one
Dec 13, 2008 | Washing Machines
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Nov 27, 2006 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
273 people viewed this question
Top Washing Machines Experts
