Question about Insignia IS-LCDTV32 32 in. Television
My volume just went out on my NS-LCD32. it worked fine this am but when i just got home it went out. i have tried evertyhing i know on trying to reset the tv and regain my volume. cant you give any suggestions?
My sound goes out on one station and none of the others. The only to get the sound back is to shut the TV off and then turn it back on. I suspect something was pressed on the remote, but I can't figure it out.
Posted on Oct 04, 2010
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
How can I reset my insignia tv #NS-LCD32 to global volume unlock with a RCA universal remote
Try this solution by another user:
timyorba 1 solutions Jul 21, 2011
So, For anybody who doesn't know yet, you do not need the factory remote to restore button functions to your Insignia IS-LCDTV26. All you need to do is program a universal remote that can power on and off the TV, then
"**press the "MUTE" Button 10 times successively**"
and Voila! Unlocked, you should see the status appear in the corner of the TV if everything worked, if not try another tv code or try the manual search function on the remote to find another compatible code set.
Dec 26, 2012 | Insignia NS-LCD32 LCD TV
Insignia ns-lcd32 has developed a vertical shadow.
Unfortuntly you have a panel that is going out. This is not cost effective to fix.
Apr 11, 2012 | Insignia NS-LCD32 LCD TV
Insignia NS-LCD32
Most likely either the main board (processes all signal) or even an issue with the power board (supplies wrong voltage somewhere).
In either case not cheap.
Mar 23, 2012 | Insignia NS-LCD32 LCD TV
Ns-lcd32 won't turn on remotely or manually
Service manual:
http://www.my.electronicshelponline.com/uploads/Insignia_Xoceco_LC-37HV41_NS-LCD37HD-09_LCD_TV_SM.pdf
Check the power supply module.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Sep 27, 2010 | Insignia NS-LCD37 37 in. LCD TV
Thank you for the help,for my insignia tv,ns-lcd32-09ca,to find the close caption,but beside that i have no manual,i also have no remote,i use the one for all remote and that works ,i still don't know how...
You can use the TV buttons to get access to close caption by pressing menu, volume up or down to select setup when you get to setup press channel down to close caption and use volume up or down to turn it on.
Let me know if you need further assistance.
Jun 13, 2010 | Televison & Video
No Sound
if you have dvd player then connect its audio out to your tv audio in. if no sound then, it might be that your audio amplifier inside your tv is the culprit. usually this happens when turning the volume fully.
Jun 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
171 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
