Question about LG 37LG30 37 in. LCD HDTV
El control remoto LG MK40653801 de mi tv 37LG30 dejo de funcionar, le cambie baterias y aun asi no funciono, y en el manual no vienen codigos para reprogramarlo. Como le puedo hacer para que funcione.?
  • 151 Answers
SOURCE: LG TV Remote
Why not buy a new universal remote and programe it for both devices
Posted on Jun 13, 2008
sabreusa
  • 271 Answers
SOURCE: Remote for one month old LG 37LG30 TV suddenly
Must be the IR receiver usually is soldered on a circuit board. Time to call your warranty..
N Sabre
Posted on Nov 07, 2009
SOURCE: lg plazma ept-4200 bp típ.tv tápja
Pl tell any Nero 8 Key number as early as possiable.
Posted on Feb 25, 2010
bbl242003
  • 1637 Answers
SOURCE: ¿como ver la pantalla donde
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
welcomejee
  • 10594 Answers
SOURCE: My LG tv has a green picture.LG 37LG30 Last time
Do you get green picture in all inputs of tv? Please unplug tv from wall socket for minute to get it reset, replug back in, turn it On and check.
Let me know to diagnose the problem.
Thanks
Posted on Aug 13, 2011
Necesito los codigos del control remoto dish ir remote 103602 para programar television jvc de 27 pulgadas
Juan Francisco! Mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Se que a este punto quizas mi ayuda ya no la necesite. Le proveere los pasos a como programar el control a su Tv por si en un futuro necesita la informacion. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor sientase libre de dejarme saber a kimberly.escobar@dish.com
May 10, 2013 | JVC Televison & Video
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Como puedo programar el control de dish para mi televisor panasonic si no tengo los codigos
Hola mi nombre es Kimberly Escobar con DISH Network. Sera un placer ayudarle proveendole la informacion que necesita. Unos codigos para la television marca Panasonic que se pueden integrar al control serian los siguientes: 685, 512, 738, and 876. El procedimiento es el siguiente: oprima el boton de T.V localizado en la parte de arriba del control hasta que los demas botones se enciendan en rojo una vez esto suceda ingrese uno de sus codigos seguido por el signo de numero por ejemplo 685#, el boton de T.V debe de iluminarce 3 veces despues de esto puede tratar de usar su control con la T.V y deberia funcionar. Si necesita ayuda programandolo este link le puede ser de mucha ayuda http://www.dishnetwork.com/SupportSection/remote-setup tambien me puede contactar directamente a mi correo electronico a kimberly.escobar@dishnetwork.com Gracias espero que esto le sirva de ayuda.
Nov 19, 2011 | DISH Network IR Remote Control
CODIGOS PARA TV GE
HOLA TENGO UN CONTROL REMOTO UNIVERSAL STEREN RM 11 Y MI TELEVISOR ES GENERAL ELECTRIC ALGUIEN SABE QUE CODIGO ES
Mar 08, 2011 | DISH Network IR Remote Control
Como programo un control remoto de dish uhf pro para usar una tele aoc muchas gracias
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televiso Aoc. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Aoc tenemos los codigos 627,566,505,659, y 664. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Feb 17, 2011 | DISH Network IR Remote Control
Como programo mi dvd panasonic con el control de dish???
Hola! mi nombre es Kimberly Escobar representante con DISH Network servicio al cliente, Entiendo que necesita ayuda programmando su control remoto a su DVD, seria mi placer proveerle las intrucciones e informacion que le pueden ser utiles para que usted pueda programar el control. Para que el control puede funcionar con su DVD existen ciertos codigos que se pueden integrar al control para que pueda funcionar el DVD. El procedimiento es el proximo: en la parte de arriba del control va a oprimir el boton transparente que diga AUX hasta que los demas botones se prendan en rojo, luego deja de oprimir el boton e ingresa el numero 1 seguido por un codigo para el Panasonic DVD por ejemplo 1639. (639 es el codigo) pero siempre van un numero 1 al principio. luego oprime el signo de numero (#) el boton AUX deve iluminarse 3 veces. Despues de eso puede tratar de usar el control con su DVD. Desafortunadamente no le podemos asugurar que funcione pero si gusta tambien nos pueden llamar directamente para obtener ayuda y mas codigos para el DVD. Gracias espero eto sea de ayuda para usted.
Dec 27, 2010 | DISH Network IR Remote Control
TENGO UNA CR-V 2003 Y ME PIDE CODIGO EL RADIO PARA FUNCIONAR
tengo un c r v honda 2003 le cambie la bateria y haoro no tengo el codigo
Jun 01, 2010 | 2003 Honda CR-V
LG 37LG30 37 in. LCD HDTV Logo
321 people viewed this question
Computer Repairing
Computer Repairing
