Question about Sanyo PLV 70 Multimedia Projector
The bulb is not bad, the bulb replacement light is not lit and the bulb appears fine- the green light goes on then off right after you start the projector ---no heat off the back of the unit when starting it up....we have had dry, then humid hot days and wonder if this is environmental...cleaned screens and have an extra external fan on it...is it normal for the red light lamp light to be on all the time? We have replaced the bulb in the past and will do so again if that appears to be the issue....
  • Sanyo Master
  • 17,130 Answers
If you have the replaced lamp with you it will be good to place it back again to see the indication to change off.
If so then the bulb must be good but if the same situation comes on then it might be the lamp.
please cross check the power supply for any errors to switch on or low power to the lamp
Posted on Sep 29, 2010
When I hit my right singal the arrow stays green instead of blinking. But my left one works fine.whats my problem?
Check the Light bulbs both front and back with it turned on if one is not lit up then change the bulb, if both bulbs are on then the relay is the most likely cause. Also some cars have marker lights that may be part of the cause.
Dec 07, 2016 | Cars & Trucks
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
2004 buick lasabre, right side turn signal blinking fast.
Check the front turn signal bulbs. This will affect the resistance in the circuit and cause the working light to flash at a much faster rate.
Aug 15, 2012 | 2004 Buick LeSabre
My rear brake light is not working, nor is my blinker at the back right. When I put the right turn signal on it blinks really fast, faster than normal, and the front blinker works. I have replaced both...
Normally with the blinker blinking really fast, it's telling you that one of the bulb is blown, front or rear signals. Check your fuse, and fuse relay to see if it would fix the promblem
Jan 23, 2011 | Chevrolet K3500 Cars & Trucks
Panasonic PTL500 LCD HIDEF projector - Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
The bulb is a discharge type - it needs a very high tension to work. The role of the ballast board is to convert the low voltage DC current coming from the power source in a high tension DC current for the bulb. Unfortunately you were truly unlucky : when the ballast board died it sent a high tension surge thru the power source and from there at the other components on the mainboard - the processor couldn't handle it and got fried. So now when you try to start the projector this is what happens: the power source starts normally - the status light goes to green as it should; it functions normally so it powers the ballast board and the rest of the mainboard - the ballast works so the bulb lights up; the mainboard on the other hand remains dead because the processor is dead so no sustain signal is sent to the power source; without the sustain signal the power source goes, as it should , in an very normal stand-by - the status light goes to red.
The entire mainboard will have to be replaced - you can't replace just the processor, it's glued in there. This is going to be expensive so ask a quote before doing it.
Dec 23, 2010 | Televison & Video
The little orange light next to the regular green light that appears when the tv is on is lit up....I suppose it has to do with bulb however the tv appears to work just fine...what does this light mean
Yes,the tv projection bulb life is ending.Sometime the LED light indication "LAMP"light up or blinkig,tv still work,because it just giving u a little advance warning that all.The "LAMP" LED indicaton light,light up right?
Sep 14, 2010 | Zenith Z52SZ80 TV
I have green light so I know the bulbe is good,
just because the green light is on doesn't mean the bulb is lit. look into the lens from the side--not directly into it to see if it is in fact lit. if it is lit but you have no display, the main board is likely bad, but you can try resetting the lamp hours and reflashing the unit with the most current firmware.
Jun 17, 2010 | InFocus X2 Projector
98 Subaru Legacy, right blinker comes on steady,can't turn it off. Left blinker works fine. right blinker will work sometimes and then it goes steday again. Can't be the flasher as I have removed it and...
Pull that bulb out and look closely at it, it'll probably have one of the filaments(Tungsten wires) broken and crossed over to the other one causing a short to power and/or the bottom of the bulb has had the 2 lead contacts melt together. In either case the bulb will need to be replaced. If this doesn't fix the problem please let me know so I can look into it further.
Jun 01, 2009 | 1998 Subaru Forester
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Sanyo PLV 70 Multimedia Projector Logo
174 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
