Question about Celestron Ultima 2000 -- 8 Telescope
Is there an user friendlier hand controller available for the Ultima 2000? Does the wedge make much of a difference?
  • 3,186 Answers
The wedge is only used if you take astro-photos. You do not need it for visual observing.
Contact Celestron support about the hand controller here:
http://www.celestron.com/c3/page.php?PageID=37
Posted on Sep 29, 2010
What user name can i use for windows security an example
I've seen Default User as a user name on Windows but Owner is just as good, friendlier as well.
Jul 22, 2011 | Computers & Internet
Serching for wireless switch on Nec Laptop Versapro NXseries
If You cannot enable 802.1x authentication on computers running Windows 2000 because support for 802.1x is not provided by default in Windows 2000. Therefore, the associated user interface (the Authentication tab) does not appear in the Network Connection Properties dialog box.
A supported feature that modifies the product's default behavior is now available from Microsoft, but it is only intended to modify the behavior that this article describes. Apply it only to systems that specifically require it. This feature may receive additional testing. Therefore, if the system is not severely affected by the lack of this feature, we recommend that you wait for the next Windows 2000 service pack that contains this feature.
The following files are available for download from the Microsoft Download Center:
Collapse this imageExpand this imagedownload.gif English Language Version (http://download.microsoft.com/download/win2000platform/patch/q313664/nt5/en-us/q313664_w2k_sp4_x86_en.exe)
After you apply this update, follow these steps to enable 802.1x authentication:
  1. Installing the hotfix installs the 802.1x service in the disabled state. To change the Wireless Configuration service startup to Automatic: Right-click My Computer, and then click Manage. Click Services and Applications, and then click Services. Set the Startup value for the service to Automatic, and then start the service.
  2. Open Network Connections by clicking Start, pointing to Settings, clicking Control Panel, and then double-clicking Network Connections.
  3. Right-click the wireless connection for which you want to enable or disable 802.1x authentication, and then click Properties.
  4. On the Authentication tab, do one of the following:
    • To enable 802.1x authentication for this connection, click to select the Enable network access control using IEEE 802.1x check box. By default, this check box is selected.
    • To disable 802.1x authentication for this connection, click to clear the Enable network access control using IEEE 802.1x check box.
  5. In the EAP type box, click the Extensible Authentication Protocol type that is to be used with this connection.
  6. If you click Smart Card or other Certificate in the EAP type box, you can configure additional properties if you click Properties and then follow these steps in Smart Card or other Certificate properties:
    • To use the certificate that is located in the certificate store on your computer for authentication, click Use a certificate on this computer.
    • To verify that the server certificate that is presented to your computer is still valid, click to select the Validate server certificate check box, specify whether to connect only if the server is located in a particular domain, and then specify the trusted root certification authority.
    • To use a different user name when the user name in the certificate is different from the user name in the domain to which you are logging on, click to select the Use a different user name for the connection check box.
  7. If you click Protected EAP (PEAP) in the EAP type box, your Windows user name and password are used for authentication.
  8. To specify whether the computer should try authentication on the network if a user is not logged on, if the computer or user information is not available, or both, follow these steps:
    • To specify that the computer try authentication on the network if a user is not logged on, click to select the Authenticate as computer when computer information is available check box. By default, this check box is selected.
    • To specify that the computer try authentication on the network if user information or computer information is not available, click to select the Authenticate as guest when user or computer information is unavailable check box.
Jan 05, 2011 | NEC Versa LX Notebook
Cant find drivers for my artec ultima 2000 scanner
Here is a link to the drivers you are looking for. Sorry, the web site requires a login so you have to register but its free and this site is great for older drivers.
Hope this helps.
http://members.driverguide.com/index.php?action=dosearch&qm0=Artec+ultima+2000+scanner&sm=s&si=77c50878bd492be2a0388fcdb524bd1a&st=1257602417&gqm0=Artec+ultima+2000+scanner
Nov 07, 2009 | Artronix Technology Artec Ultima 2000...
No handbook
Try finding the handbook in here, if that is not available call them by phone.
Check also WM72 Quick Guide.
Jan 15, 2009 | Hotpoint Ultima WD72 Front Load...
Want to update artec ultima 2000 scanner software - suggest a free download site please
SIR I HAVE ARTEC ULTIMA 2000 SCANER I DON'T HAVE CD FOR SOFTWARE PLEASE SEND THE FREE DOWNLOAD
Dec 20, 2008 | Artronix Technology Artec Ultima 2000...
Hi i have a some of queries i want to download driver of the scanner artec ultima 2000
You can download driver for Artec Ultima 2000 here:
Artec Ultima 2000 driver
But, this driver is for Windows 98/ME/2000/XP. Unfortunately, there is no driver available for Windows Vista.
Please rate the solution...
Thank You
Nov 14, 2008 | Office Equipment & Supplies
After alignmentment, scope points backwards
If you can RESET the hand controller do it-- then re-enter TIME, DATE, and SITE. Make sure you are in ALT AZ Mode and NOT Polar Mode if you do not have a wedge.
This is probably the issue-- you are in POLAR MODE by mistake.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Mar 29, 2008 | Celestron Ultima 2000 -- 8 Telescope
User manual required(hotpoint ultima wma60)
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
If your number is not above click on Hotpoint.
Rate me pl if helped...................
Mar 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Optics Logo
244 people viewed this question
Top Celestron Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Vernon Taylor
Lawrence Oravetz
Are you a Celestron Optic Expert? Answer questions, earn points and help others
