Question about IBM ThinkPad R52 Notebook
The fan on my R52 has been getting noisier of late, and now when I turn on the laptop it makes a fan noise (as bad as it has been) and after about 4 seconds the laptop shuts down and Fan Error is displayed in the top left hand corner of the screen.
    Guru:
  • 1,481 Answers
FAN is out...replace fan...else ur processor will die soon....dont use the machine....take it to a tech shop and replace fan ASAP....
pls revert back...kindly give a feedback and rating to this solution....it will help me move to the next level "Guru,,,,"
regards
Posted on Sep 29, 2010
Ariston 1600 wd been getting noisier lately, now its sounds like a airoplane taking off and there is load knocking noises, is it worth repairing as it is a few years old now and out of warranty
Hey, ours was the same. Turns out the dryier element was loose and was causing the knocking sound....couldnt talk over the top of the noise.
About 100 to get the ariston guys out to fix it.
Was worth it for us....
Aug 18, 2011 | Ariston Technologies AWD120 13 lb. Washer...
We turned on our 1.5 hp air con Fujita on the heat setting, the compressor would run but the fan would not work. The compressor became noisier so we turned it off. On the cool cycle the compressor ran and...
the compressor got noisier be cause the head preasure was going up putting a strain on the compressor check all your wires from the fan motor and make shure they are all hooked up and than check the capacitor for the fan it may be bad usualy it will leak fluid or be swollen when bad. but not allways if you can turn the fan by hand is prob. not bad its prob. another prob causing it not to turn
Sep 30, 2010 | Heating & Cooling
My whirlpool dryer seems to be noisier than normal. It seems that the tub turns with more resistence lately. The dryer works and gets the job done but it is noisier than in the past.I have taken the back...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 28, 2010 | Whirlpool Dryers
Fan noise
This is just a consequence of normal wear & tear, most Laptops, & Desktop's Fan's actually sound louder over time as the bearing in the fan wears, this causes more noise, it is not too much to worry about. I guess you could replace your fan, but it would mean disassembly of the unit. Get a program called Speedfan, with this you can control your fan, this may help. link below. http://www.almico.com/speedfan.php
Feb 23, 2010 | HP Compaq nc8000 Notebook
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
Loud buzzing noise......possibly the fan?
is the battery ok? have it tested, sounds like a weak battery that is failing, the battery lasts about 2 years in most laptops.
Sep 04, 2009 | Compaq Presario Fan
The fan is making a lot of noise. this has
Is the laptop dirty inside?
If it hasn't been cleaned out regularly, with a can of compressed air for computers, more than likely it is.
Laptops typically have a poor cooling design. For one, everything is crammed into a tiny box.
For two, there is a small duct, (Air Intake Duct), that draws air in.
For three, laptops typically just have 1 small fan.
For four, the Air Intake Duct is located on the bottom of a laptop, or on the side.
This is an excellent (?) area to draw foreign debris in. Another word for foreign debris, would be CRUD.
Hair, Food Crumbs, Lint, Dirt, Dust, and so on.
A laptop's cooling systems primary function is to keep the Processor at a certain temperature. If the processor becomes too HOT, it turns off. (BIOS turns it off)
NO Processor, No computer!
1.The excessive fan noise can be that the fan is spinning at top rate, trying to keep the processor cool. It's having a hard time doing that, because the fan cannot draw enough air in. (Clogged Cooling System with Crud)
2.The excessive fan noise could be that the fan's bearings are bad.
3.The excessive fan noise could be that the Processor is running at 100 percent, (100%), and the fan is running at full speed, in order to keep the processor cool.
Perhaps caused by a virus, or some sort of anti-virus program, or running more than one virus program. (Installed a new anti-virus program lately?)
Aug 04, 2009 | Computers & Internet
I recently replace the fan in my IBM Thinkpad R52. Ever since, when using the power cord it suddenly shuts down after booting for about 10 seconds. But if I use the battery it boots fine.
I would open the case back up to make sure nothing else got moved around when you installed the new fan. If it was close to where power plugs into the laptop, you might have knocked something loose that could be either stopping the fan and causing heat to shut you down, or causing a short when the fan varies its speed.
Mar 16, 2009 | IBM ThinkPad R52 Notebook
I had a Panasonic bath fan installed the week before Thanksgiving. It was represented that this fan was virtually silent. It is however, noisier than the 22-year old fan it replaced. My contractor tells...
Vibration noise is usually due to inballanced, or damaged fan blade.
Take off the coveer, make sure its installed properly, the blade is not cracked, and check for ballanced motor/bracket/blade.
They typically have rubber bushings between the motor mounts and the housing to dampen vibration noise.
Dec 17, 2008 | Heating & Cooling
R52 laptop screen stays blank
Try removing the battery and starting up just on power supply. May be a bad battery. If that doesn't work let me know.
Jun 06, 2008 | IBM ThinkPad R52 Notebook
IBM ThinkPad R52 Notebook Logo
97 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
