Question about Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera
Screws holding the wrist strap fell out. How do get the right ones, or where?
    Brigadier General:
  • 11,967 Answers
You could try a jewelry store or a watch repair facility.
Posted on Sep 29, 2010
How to replace harddrive
You have to open the desktop case to get access to the HDD, then remove the mounting screws holding it in place, and disconnect the cables. Revere to install new one. Use of a ground strap on your wrist is advisable so any static discharge won\'t fry any on the chips etc.
Aug 25, 2014 | Gateway ZX690049 23Inch AllinOne Desktop
Where do I install the memory card & attach the wrist strap? Quick start manual lacking info.
Memory card goes in a slot beside the battery, under same cover as battery. Wrist strap attaches via two small holes right side near top (holding it as you would use it). Thread the stiff thin thread through the holes then pass the carrying end through the loop that exis the far hole.
this link may help http://downloadcenter.samsung.com/content/UM/201405/20140526112017221/WB35F_English.pdf
Jul 23, 2014 | Samsung WB35F Smart Digital Camera White
Casio gw-500, trying to change the bands, screws keep turning
For G Shock GW500Uthe screws holding the ******** are actually just one pin per strap the screw end is for decoration. To remove just get small headed flat screwdriver and push pin through it is fidely but can be done it took me 10 mins first time. Casio sell straps direct for about 10 pound cheaper than putting into casio dealer .
Jun 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
How do I install the wrist ******** my vivitar vivicam 5022?
The wrist strap hole is on the upper right corner of the outside body when you are looking through the viewfinder. Thread the skinny end (or one end) of the wrist strap through that strap hole. As soon as a little loop (like 1 inch) is poking out the other side, thread the thicker (or the other) end of the strap through that loop that's poking out of the strap hole. pull tight.
PLease "accept" so i get credit!! Thanks, Scott
May 27, 2011 | Vivitar ViviCam 5022 Digital Camera
How to remove Canon A570is broken battery door
I had the same problem and found nothing online to fix it so based on what little I could find and some common sense I got it done fairly easily. Here's what I did...if you need more detail on any step either re-read it to see if you missed something or let me know 'cause maybe I missed something.
Standard warning - you are dealing with small screws, small parts and things that might break. If you damage your camera trying this repair - please don't blame me! <G>
1) remove batteries and memory card
2) carefully remove screws around the outside.
There are: 3 on the bottom, 1 under the plastic usb cover on the left side, 3 on the right side. Once those are out, remove the clip that holds the wrist strap and you'll find 1 more on the top of the camera under the wrist strap clip.
3) starting at the bottom of the camera, gently separate the back cover from the camera body. YOU DON'T NEED TO TOTALLY REMOVE THE COVER!
4) (note the small spring on the battery hatch - when you complete the next step that spring will come out so look at where it is, which way it is and don't lose it!) While holding the cover and camera body apart slightly, use a pair of fine needlenose pliers or possibly tweezers & slide the pin that holds the hatch in place toward the back of the camera until the spring and door come off. You don't need to totally remove the pin.
5) take your new door assembly and put it in place. the fun part is the little spring - the shorter end of it has to go through a small hole at the back of the hinge area, the longer end puts pressure against the hatch. Once the spring is in place, hold it there and slide the pin back into place (I found that just allowing the cover and body to come back together moved it into place).
6) try the hatch to make sure it opens/closes freely and latches
7) put the screws back in place - note that one of them is shorter than all the others - that one goes on the top of the camera under the wrist strap clip
Hope this helps!
Please note - this is the only digital I've taken apart so I'm not likely to be able to help with other makes and models but feel free to ask!
Jun 14, 2010 | Canon PowerShot A570 IS Digital Camera
How can a PC technician protect against damage
by wearing a grounding wrist strap, they are avil on line
Sep 10, 2009 | Computers & Internet
How do you remove the pin out of Starck and Fossil PH1100 watch?
Ok, so if you are like me then you probably thought removing the three tiny screws from either side of the strap, and cutting segments of the strap and re-screwing the clasps back was going to do it. Unfortunately one realises that the clasps do not slacken to let the rubber straps out even after the screws are off. The critical point is to get the side pins out which is no simple feat. Getting the pins out releases the clasps and the rubber strap.
To get the pins out, use a wire cutter to cut down a paper clip to a length of 1 .5 cms or so. Hold this with a pair of tweezers along the axis of the pins while you hammer down in the direction of the small arrow inscribed on the metal clasp. With persistence a part of the pin comes out from the other end and you can then pull it out completely with a pair of pliers.
Removing the two pins with release the ends of the rubber straps. cut away segments as required while trying on so that you dont cut too many. Make sure you cut the same number of segments on each side. I had to cut three from each side since I have very thin wrists.
Now put the rubber strap back hold the clasps in position and push the pin back in place. Put the screws back and you should be in business.
It sounds complicated but is quite simple if someone shows you how....which I hope I have been able to.
Sudipto, India
Sep 09, 2009 | Watches
Skagen watches - the glass broke
Any watch repair shop can replace the glass. Find the nearest one and ask for help.
Jul 29, 2009 | Skagen 170LTTM Wrist Watch
Need to repair wrist strap attachment on ixus 960
First things first, the small piece that holds the strap, when broken is repairable, but it is best that you dont since there is a strong possibility that the line will give up. the best options you may have to look for are camera pouches that are designed for the camera.
http://farm1.static.flickr.com/186/452068540_bf62b87687.jpg?v=0
http://ecx.images-amazon.com/images/I/51KXXHF3Q0L._SL500_AA280_.jpg
http://farm3.static.flickr.com/2117/2324527140_d133db348b.jpg
Jan 02, 2009 | Canon IXUS 960 IS Digital Camera
Canon PowerShot SD790 IS/ IXUS 90 IS Digital Camera Logo
156 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
