Question about Cosco Metal Crib
The peace that goes to the side to snug in to the drop is missing...looking for that round piece ....any idea where i can find it
    Scholar:
  • 53 Answers
This crib is no longer being sold and Cosco no longer makes cribs at all. Drop-sided cribs are known for falling apart, having missing parts and children end up getting entrapped between the broken drop side and the rest of the crib and dying. Please, do not try and repair this crib, just throw it away. It should not be used for any child. Do not take the risk. It isn't worth it.
Posted on Sep 29, 2010
The deck on one side is on ground
There is more than likely a broken "float" chain on the side that is dropped. Could be a rubber bushing. Not really a lot to go on. You should at least look at the side that is dropped for a piece that either appears to be missing or broken.
Jun 01, 2016 | Garden
How to replace the gas filter on a 2003 chevy suburban
get under car and look from tank for line that goes to front engine, there will be a round piece on the fuel line- don't get mixed up with brake line that goes to wheel- replace round fuel filter about 3 inches long- two nuts on either side - use two wrenches and loosten- replace in same fashion
Feb 18, 2014 | 2004 Chevrolet Suburban
The piston won`t retract in order to load the next nail.
Piston not retracting is caused by several issues including bent driver blade, piston oring too worn, or check band on the outer part of the cylinder broken / out of place. Easy to check. Remove the head and pull the driver. Examine driver for bend. If not bent insert driver into cylinder and check for worn oring. The driver/oring should fit snugly and driver should hold in position in the cylinder without sliding down the cylinder under its own weight. Examine the lower bumper for missing pieces or cracked. Replace as needed. If driver /oring and bumper are ok, pull out the cylinder and examine the check band. Black piece of rubber covering series of small holes. Should fig snugly on cylinder, replace as needed. Repair kit does not include the lower bumper or the checkband. Good luck with your repair.
May 30, 2011 | Dewalt D51850 Heavy Duty 20 Degree Full...
I bought replacement blades for my John Deere 54 inch cut and they came with a round center hole and the ones already on there have a jagged center. Is there a piece to fit inside round hole to make blade...
Those piece you are looking or should have come with the replacement blades , if not you might be able to find them at you local home center ie: lowes ,home depot..
Apr 02, 2011 | Garden
Why won't the driver retract on my pneumatic stapler
Can't be more specific without model number.
Driver not returning to top of cylinder is caused by several issues. Bent driver, piston oring, and check valve. Remove head and pull out driver. The blade should be straight with no missing pieces. Driver piston should fit snugly into cylinder and not drop down cylinder under its own weight. If driver / piston look ok, pull out cylinder and look for check seal in place. It looks like rubber band or one or more orings and fit in groove/s with row of holes (make sure holes are clean). Other problems related to driver not returning is/are lower bumper is missing pieces or cracked and or air exhaust port is restricted, low air pressure. Parts are available at www.toolpartsdirect.com
Mar 28, 2011 | Senco Air Tools & Compressors
Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
May 21, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
HP Officejet 7210 All-In-One printer two-sided printing
Had the same issue with an Officejet 7210.
Basically, what the printer is trying (not very well) to tell you is that it is not capable of handling the entire two sided printing project automatically - which for reasons that are completely obscure is the default setting for two sided print jobs - way to go HP!
To solve the problem, open up the printer's properties window (or preferences depending on your approach). On the printing shortcuts page, you should find a drop-down menu entitled Print on Both Sides. This drop down should read 'Automatic' (which indicates that the printer will print the first side, flip and reload the paper and print the other side without any intervention - yeah, riight). Simply change this setting to 'Manual' and the problem is solved!
Happy printing!
'Doc'
Nov 23, 2008 | HP Officejet 7210 All-In-One InkJet...
Cat jumped on top of printer and 2 pieces popped out
Hi there you will have to remove the top cover and you will be able to see where it goes as the roller in question is the paper eject roller. there are usually four screws under the top cover and also at the rear of the machine. The picture where the roller is resting on the top of the printer the roller is situated right under that also that white bushing holds the roller in at one end usually the left as you look at the machine from the front.
Thanks J
Jan 20, 2008 | Brother HL 5250DN Laser Printer
Cosco Metal Crib Logo
152 people viewed this question
Top Cosco Baby Gear Experts
doconnell13
Jennifer Rock
Jennifer Rock
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Cosco Baby Gear Expert? Answer questions, earn points and help others
