Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
My 5GHz connection is listed under connections but is not available. The2.4GHz is available but very weak and slow. I know that the 5 is working because my laptop connects to it. (I'm using a Windows 7 64 bit Dell). Can you help?
  • 7 more comments
  • rdenes Sep 29, 2010
    Hi Rodietom,
    I have already disabled the Microsoft Virtual Wifi Miniport Adapter because I was getting an error message that Windows cannot load the drivers (31). Then I installed the updated Dell driver -- Atheros Wireless 1525 WLAN Minicard Desktop. I've just updated the driver as you said. Still can't get 5GHz.
    How do I disable wireless zero config?
    Hi, I won't be home in front of my computer until evening, New York time. Will describe what I see then.
    Thanks.
    Hi lyzmorato,
    When I click on Manage Wireless Networks that use (Wireless Network Connection) it says Windows tries to connect to these networks in the order listed below
    I see
    westendwireless Security WPA2-Personal Type: Any Supported Automatically connect
    NETGEAR-24-G Security WPA2-Personal Type: Any Supported Automatically connect
    Then, when I click on Network and Sharing Center, I see
    View Your Active Networks_______________________Connect to network
    You are currently not connected to any networks
    Westendwireless is the SSID for my 5GHz connection
    NETGEAR-24-G is the 2.5GHz connection.
    Right now, I can’t connect to either of them.
    But I know the wireless is working because I'm using it now from my laptop.
    Thanks,
    Ronni
  • rdenes Sep 30, 2010
    Now, it's about 45 minutes since my last email to you. For no
    apparent reason, I am connected through the NETGEAR-24-G SSID. It shows
    up as an available connection in the network and sharing center under
    view your active networks. Westendwireless does not appear although it
    is the preferred choice.
    I can't find a record of my posts, so I don't know if I already sent this to you successfully.
    I see
    NETGEAR-24-G is the 2.5GHz connection. Right now, I can’t connect to either of them.
    Now, 45 minutes later, for no reason, I am connected to the NETGEAR SSID and it shows up under active networks.
    Hi, I'll be back in front of my computer this evening, NYC time. Thanks, Ronni
  • rdenes Oct 01, 2010
    OK... I restarted the WLAN auto config, but couldn't find anything called wireless driver properties under device manager. By the way, although it is a wireless router, it is connected to my computer with an ethernet cable. It did work this way in the past. How do i change router settings?
    At this point, even the 2.5 connection is so weak that it won't hold.
  • rdenes Oct 02, 2010
    Hi, won't be back in front of my desktop until tomorrow evening. Let me understand... are the directions above to use the wireless or to return to broadband? Right now, when I try to view available networks, only the wireless networks are visible. What's crazy to me is this all seemed to work in its current configuration until Dell "fixed" my computer after a "catastrophic failure - blue screen." I do need the router for my laptop, which right now has saved my ability to communicate. If I want to access the internet through the ethernet cable, do I have to change the driver or adapter settings? Sorry for all these questions, but as you can see, I'm working way above my knowledge level. Thanks for you patience.
    R.
You will need to update the firmware, click on the link below to get started:
http://kb.netgear.com/app/answers/detail/a_id/849
Posted on Sep 30, 2010
    President:
  • 1,566 Answers
Hello there,
Where can you see that the 5Ghz is unavailable?
Posted on Sep 29, 2010
  • lyzias morato Sep 29, 2010
    Alright. Let me know once you are back so that we can troubleshoot further.
  • 629 Answers
If it works at 5GHz using your other laptop, it would be something to the wifi adapter of your Dell system. confirm the specification of your wifi adapter, update its driver and disable Wireless Zero Config service if available. Make sure to try the wifi connection with the adapter connected to your system if you are using a laptop. Let me know how it goes.
  • 2 more comments
  • Rodie Sep 30, 2010
    try going to Start, type services.msc in the Search box and click it from the list that will come up. From the list of services, look for WLAN AutoConfig and make sure its properties is set to Auto-Start and the service is started. Also, try going to the Device Manager, double-click the wireless driver properties and on its Power Management tab, uncheck the option to let Windows disable it. Make sure on its properties, the correct channel is also selected. Then on your router, set the wireless setting to mixed mode if you have any device using the N mode. If you only have B and G modes, set it to BG-Mixed if available, and set the channel width to mix. Save your changes and test the connection again. in case you need further help, could you indicate your Dell system model? Let us know how it goes.
  • Rodie Oct 01, 2010
    no worries, we're here to try to help you sort this out. just post back with any updates.
  • Rodie Oct 02, 2010
    sorry for the late reply. got hooked up with work. If the router is connected through an ethernet cable to the computer, this means, you are using a wired connection and not the wireless option. If this is the case, wifi is not needed unless you have another computer that needs wireless connection. If you need to access the router, often, you can go to 192.168.1.1, though to verify, click Start, then type CMD and click CMD.exe from the listed items. Type ipconfig/all in the command prompt and press Enter. Look for the default gateway which will represent your router. Once you have the address, type it in your browser to access it to get to the router configuration page. If prompted for a password, try leaving the user name blank and admin as the password if you have not configured it yet, otherwise, enter the correct user name and password. you can also refer to the router manual for the default name and password if you have not set it up before. Once you are in, you can change the wireless settings.
    The information that I have provided is to set up and use wireless if
    you need it. Based on your current set up, if your computer is connected
    directly to the router via an ethernet cable, this means, you are using
    a wired connection. If that is how you always do it, wifi is really
    not needed. However, if you have another system like a laptop that will
    use wireless instead of an ethernet cable, you can check the steps that
    I have provided to verify your wireless settings/configuration. To continue to access your computer using ethernet cable, you just need to connect the cable to the network port (RJ-45) on your computer either desktop or laptop. If the network adapter of your computer is already set up with the proper driver installed, it should be able to connect to the network/internet. If you still need help with wireless, it may help if you can provide me the service tag of the computer, or at least its specific model. This way, we can try to check from the Dell support site on its actual wifi adapter driver.
How do I switch to a 5ghz WiFi signal on my next book area 8 premium edition with 802.11 b/g/n
It is not possible to connect your PC to 5 GHz network. Its wireless card has no capability for 5 GHz band. See this answer for similar question:
Get 5Ghz on laptop
You can buy additional Wi-Fi adapter supporting 802.11a/b/g/n or 802.11ac standard.
Dual band adapter example is here:
WiFi AC Adapter Dongle GMYLE Wireless AC1200 Dual Band 802 11ac USB3 0 866...
Jan 27, 2016 | Computers & Internet
How do i know if my laptop can get 5GHz from my broadband router ?
Go onto the router homepage, go to advanced wireless settings and select 5GHz. It is not possible for older devices (3years+)to connect, however
Jul 19, 2014 | ASUS Computers & Internet
I cannot connect to my 5ghz band, only the 2.4ghz band
i think the best thing to do would be to make sure your 5ghz router settings, make sure they haven't been altered, or reset.
Jan 29, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
My new Acer Aspire one 722 wireless connection tested fine at the store. Web pages and file download is as expected for high speed network. When I brought it home to my high speed network, web pages and...
could be just different wifi chipsets. these days also you may have 2.4/5ghz(802.11ac) what router do you have? most routers are now DUAL SIGNAL and have a 2nd wifi signal called GUEST generally this is for older slower WEP based security for old devices(which is what you have) as aspire one 722 is 802.11 b/g/N but not 5ghz and not ac. so its slow cos the router probably keeps negotiating for faster connection but your aspire cant do it and doesnt even know about it. Enable GUEST in your router and set it to N. How to Find the Best Wi Fi Channel for Your Router on Any Operating System https://www.forbes.com/sites/gordonkelly/2014/12/30/802-11ac-vs-802-11n-wifi-whats-the-difference/#6ec777d23957
Dec 20, 2017 | Acer Computers & Internet
F7D8302V1 is only broadcasting the 2.4ghz Wireless G SSID (SSID = Belkin.5d94 ) The 5ghz Wireless N SSID is set to "MyTV". This SSID doesn't show up as broadcasting on any devices...
This might not actually be an issue. The 5ghz band is not available on a lot of devices. Unless your device says it supports 5ghz, you will not see it. All cell phones I know of, blackberry's, iphones, etc... use wireless G, or N 2.4ghz. New devices like HD streaming video players, media extenders, 2010-2011 MAC's and some new PC laptops support the 5ghz band. Your configuration screen shot looks fine. Verify that your devices support 5ghz.
My MAC book PRo 2011 supports 5ghz and so does my Asus Laptop. These two devices connect to the 5ghz and all my other devices, including my blackberry, connect to 2.4ghz.
Regards, Chris
Jul 01, 2011 | Belkin (F5D7231-4) Wireless Router
We have anew dual band max plus 600n belkin router. Our laptops connect to the 5speed connection there is supposed to be a wireless 2.4 connection as well. The laptops are not getting sight of this. We...
hey dude i have the solution for your answer
1>connect the computer to the router wired type http://192.168.2.1
2>on left side u can find wifi protected setup disable it for 2.4GHZ & 5 GHZ
3>now click on security - under 5ghz click on secuity mode - > disable security->apply changes
4>now for click security mode for 2.4 GHZ -SELECT 64 BIT WEP - ENTER 10 DIGIT NO AS PASSWORD APPLY CHANGES
5>CLICK CHANNEL & SSID ON LEFT SIDE UNDER WIRELES - >UNDER 2.4GHZ CHANG SSID TO ANY NAME U WISH APPLY CHANGES IT WIL WORK
LET ME KNW IF IT WORKS THANKS MILAN
Jan 19, 2011 | Belkin Play N600 Wireless Dual Band Router...
My Belkin Wireless router has always only one or no bars of connection and my internet is always running slow or cant connect. The router is in the next room near the phone line with one single brick wall...
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 22, 2010 | Belkin (F5D9230-4) Wireless Router...
Hey I cannot add a coment to the last question I asked and you answered about the xbox360 and wireless N connection so I will try here. This website would not let me submit a reply instead it was telling...
those you mentioned are channel frequencies ..and in this case in a bandwidth pf 5 ghz...are shown like you mentioned..and they indeed have numbers from 1 to 12 in the other case...choose one in the middle for better reception...if you have problems with the speed just change it untill you have the max speed available ..
the issue is that it will affect the connection with the others and you will have to tune them to the new chosen band..but will all work ...
here is not shown the initial question ..but I believe that was related with the security of the connection ...for that ...enable the security for that you have to change the ssid ..and choose a name for your network ...Under this name you will see the connection when you are looking for it ..
second ..you have to enable and configure the password
Change the WEP (wireless encryption protection). Referred to by some router manufacturers as a Wi-Fi protected access, this is basically another layer of protection so that only those who know the password can log onto your network.
you can also leave the network with no password..but enter the Mac access ..in this case only the chosen mac addresses will have access to the network ..
in what regards the comment that you could not add to the first post ...you should take a better look cause in the right side it has a post comment little link ...it is not normal to have to accept an answer to post a comment ..the idea is to change comments with the expert until you are satisfied and after that to accept ..so ..probably you wanted to make another post and had to reject or accept so to be able ...but to post a comment its not right ..take a better look ...next time ..cause it may cost you money each time you make a new post ..
Apr 21, 2010 | Computers & Internet
How do I force my built in wireless adapter to run in 5 Ghz mode (instead of 2.4) on a 802.11n network? It's an Intel WiFi Link 4965AGN
Does your router support the 5GHZ network?
My router supports dual-band at 2.4 and 5, and has separate SSIDs for each of them.
ie; network_1 = 2.4GHZ, network_2 = 5.0GHZ
So when I want the 5.0, I just connect to network_2
It's quite possible that though your wirelses adapter supports 5.0, that your router doesn't.
Mar 20, 2009 | ASUS Operating Frequency 2.4 - 2.5 GHz...
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
112 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
