Question about MSI 648 Max-L (MS-6585-020) Motherboard
No audio all of a sudden. Might have unplugged a wire when cleaning out dust inside case. Need to know wiring diagram for audio connectors.
    President:
  • 1,768 Answers
Here is where you can download the manual and see the board layout and connection for *********** board model.
http://www.msi.com/index.php?func=downloadfile&dno=3576&type=manual
Posted on Sep 29, 2010
    Problem Solver:
  • 15 Answers
Http://www.msi.com/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=501
there is the manual
I need to see a diagram on how to replace headlight harness connector that is located inside the headlight on 2004 chrysler crossfire
Pull the rubber dust cover back you will see the electrical wires going to the bulb you can pull the old connector off from there it is not inside the housing, the bulb is held in by a small spring clip at the back of the bulb socket.
Sep 06, 2014 | 2004 Chrysler Crossfire
Headlight wiring diagrams
You can buy the replacement pigtail connector at the auto parts store the connector plugs on the back of the bulb inside the tube on the back side of the headlight box you remove the rubber dust cover and pull the old connector off the bulb plug in the connector on the pigtail and splice the wires to the old headlight wires all of this is done outside the headlight box there is no need to remove the headlight box.
Sep 05, 2014 | 2004 Chrysler Crossfire
Had a bad tornado/storm in my location, after the storm my x5 has been giving me major problems. not with motor just wiring electrical shorts idk what is up took it to my machacnic and he is going to...
You do not need to drive it off of a cliff. Wiring diagrams also will probably not do a lot of good in this case either. What you need are connector location diagrams. The GEM is in the engine compartment and is the most likely suspect here. What needs to be done is to disconnect all the electrical connectors that you can find and inspect the terminals inside. The GEM would be a real good place to start. Any terminals that have corrosion need to be cleaned or replaced. I have had several "high water victims" that I have fixed by simply disconnecting connectors and cleaning the water and corrosion out and then apply a coat of dielectric grease to the terminals before reassembling.
If your mechanic needs diagrams etc. to figure all this out, your best bet would be to have him get a subscription to AllData. You can get a 1 Year subscription for your vehicle for about $27 (USD) per year. This will give you all of the information for all of the circuits in the entire vehicle, including connector locations. (Click the link below for more info.)
ALLDATA DIY
Nov 25, 2011 | Cars & Trucks
Where is the oil pressure switch located on a 1999 grand marquis located
sensor (sometimes called a switch, as well) that will light up an indicator inside the car to inform you of the low oil level. In some cases, checking the dipstick will show that there is actually oil present, which can be confusing and frustrating because it contradicts the sensor. If this happens to be the case, more than likely the oil pressure switch/sensor is malfunctioning and will need replacing. With a little bit of skill, you can learn how to do it yourself
  • which is either behind the distributor or on the driver side of the block in the lower right hand corner between the header and the oil filter. Look closely at what parts surround the sensor. Remove the parts that are in the way and look for the sensor. If you do not know how to remove these parts, consult your owner's manual for further information.
  • 2 Locate the rubber dust boot on the connecting wires and pull it away. The dust boot is an accordion shaped cover that keeps dust from getting in between joints and shafts. Push in the tab that is holding the connector in place and unplug the wires or wire harness. Clean all the contacts if desired or necessary.
  • 3 Remove the new sensor from the packaging and place it somewhere accessible. Loosen the old sensor using an open-ended wrench or extended handle, if space is limited. Pull out the old part, having a rag handy to plug the socket in case oil pours out.
  • 4 Reverse the steps to install the new sensor and plug the wire or wire harness into place. Ensure that the part is snug but not too tight
  • Dec 01, 2010 | 1999 Mercury Grand Marquis
    I've lost the wiring diagram
    I couldn't find a manual or wiring diagram for this model, but I am fairly sure this is it:
    Yellow - Constant +12v (for memory retention)
    Red - +12v Switched (ACC)
    Black - Ground
    Blue - Power Antenna
    Orange - Illumination
    Green - Left Speaker
    White - Left Speaker
    Purple - Right Speaker
    Gray - Right Speaker
    Jul 19, 2010 | Pyramid 100S Cassette Player
    Need the wiring diagram for a audio-technica
    I believe on the 4 pin connector of the pack, pin 1 is shield/ground and pin 2 is low impedance input. One of the other pins is bias voltage and the other is high impedance.
    In the UNIT I had, there was a connection diagram someplace in the battery compartment, either on the cover or the case. As I recall it had poor conrast to read and find it so check closely.
    Sep 27, 2009 | Audio Technica (ATW-T201-T2) Microphone
    Need a wiring diagram for a Insignia ns-c5112 cd car stereo
    you can order one from here:
    http://www.mcmelectronics.com/product/INSIGNIA-/C-501800-77235
    I had a wiring diagram, but I sold the radio and the diagram went with it.
    Apr 04, 2009 | Car Audio & Video
    Wiring diagram
    Hi, Put "Vintage schematics" into your search engine and it will take you to a link.
    Kind regards
    David
    Oct 14, 2017 | Audio Players & Recorders
    Front panel audio connection to asus pk5 se mobo
    Hi Tracybow,
    The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
    I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
    Hope this helps.
    Best regards
    Eduardo
    Oct 03, 2008 | Computers & Internet
    MSI 648 Max-L (MS-6585-020) Motherboard Logo
    161 people viewed this question
    Top MSI Computers & Internet Experts
    vsri9
    David
    David
    Matthew Spark
    Matthew Spark
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
