Question about KitchenAid Refrigerators
Trying to put new seal on freezer door - KitchenAid Refrigerators
    President:
  • 1,314 Answers
I need to send you some pictures for this or you cand damage the door email me at b4829@yahoo.com check this soultion as accepted so i get my four boxes but the pictires are to large to send on this site just reference door gasket in yor e mail
Posted on May 25, 2008
3 Suggested Answers
  • 112 Answers
SOURCE: new 642 freezer door is very hard to open due to seal sticking
If the seal or seating area is sticky, wash it with warm water. If it isn't, this is just the sign of a good refrigerator. As the air cools, it becomes more dense and creates a vacuum inside the compartment. With a pliable new door seal which is sealing well, combined with a large door, this can cause a great seal with alot of pressure pulling on it. Smile, this is why your consumers bill will be much better with that new sub-z.
Posted on Oct 18, 2008
bobicehouse
  • 1524 Answers
SOURCE: Need to replace freezer door seal on Hoover HFA29K
This is probably a "push in" gasket.
Posted on Apr 23, 2009
The frost free freezer has started to form ice
First point of investigation, is to check the door seal. Sometimes new seals get stuck-suction and when opened and shut possibly cause a small tear, lubricate very gently with Vaseline, this will enable the seal to firstly seal properly and secondly not put undue pressure due to suction on new door seals.
If that does not resolve it then have a technician check the thermostat.
Mar 04, 2015 | Frost Refrigerators
Freezer door does not make vac sound
Might need a new seal.
A better test than sound is the put a dollar bill in sealing area and close door. Check how hard it is to pull dollar out (check tightness).
Do this all around the door in various spots.
Jul 22, 2013 | Freezers
Freezer door won''t open, was frozen shut, used a hair dryer and then could open but now it doesn't open all the way and seems to stuck on left side.
take defrost the freezer it sounds like ice has builded up behind the door and it sounds like u may need a new door gasket or it didn't get closed all the way.
here is something u can try to see if the gasket seals take a dollar bill put in the door frame shut the door if the dollar bill comes out easy the gasket is not sealing
Apr 02, 2011 | GE Profile Stainless Bottom-Freezer...
Bought new 8.8 stand up magic c freezer can't get dr open
Bought the same freezer from Home Depot, door would not open did find with a bit of detective work that if you place your fingers between the door gasket and the shell of the freezer you can break the glue type seal then door works fine. You must go across top and down both sides.
Oct 05, 2010 | Magic Chef 11.8 cu. ft. / 334 liter...
ICE DOOR SEAL IS LOOSE AND NOT SEALING CAUSING FROST BUILDUP
This is the step you will use to repair your ice door seal that is loose.
There are screws under the fold of the freezer door gasket that holds the brace for the gasket in place. Lift the rubber gasket to expose the screw head, one section at a time. Just loosen the screw, and do not take it completely out.
As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
Check the seal by closing the door. You should have a nice, tight seal.
Good luck.
  • Step 4 Tighten the screws into place. This may have to be done once the entire gasket is fitted into place.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7rn3O8
  • Step 3 Continue around the freezer door, unloosening the screw, taking out the old gasket and fitting the new one in.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7gYaZ2
  • Step 2 As you loosen the screws, one section at a time, carefully remove the old gasket. At the same time, fit the new gasket into the groove. Make sure your new gasket is lined up properly.
  • Step 5 fix-freezer-door-seal-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/k5/eg/fix-freezer-door-seal-1.5-800X800.jpg'); }); Keep the gasket clean to last longer. Check the seal by closing the door. You should have a nice, tight seal.
  • Read more: How to Fix a Freezer Door Seal | eHow.co.uk http://www.ehow.co.uk/how_4855248_fix-freezer-door-seal.html#ixzz0rY7JfY8i
    Jun 22, 2010 | Refrigerators
    Freezer door of electrlux freezer keeps coming
    Try cleaning along seal and seal itself. If it does not work get new seal. The seal do go bad after a while.. If under warranty call dealer you purchased from for them to replace.
    Jul 06, 2009 | Freezers
    Kenmore freezer
    if the gasket isn't torn and the gap isn't caused by a door hinge problem you might try putting some vaseline on the door seal. If that doesn't help you may have to replace the seal.
    Dec 30, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
    New freezer has bad door seal
    it often works to warm the seal with a hairdryer and reshape it
    Nov 29, 2008 | Haier Freezer HUF168PA 16.8 Cu. Ft....
    Freezer seal
    Turn the machine on to full empty all contents and leave for about 30 minutes then try to close door if doesn't work check the seal for splits.
    Thanks J
    Feb 01, 2008 | Freezers
    Door not sealing
    After putting a new gasket on you will usually need to form it. You can use a hair dryer to heat the gasket and flat screw driver to form it.
    Nov 07, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
    Refrigerators Logo
    56 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    vince
    mike cooper
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
