Question about Smeg SE250XUK Stainless Steel Electric Single Oven
What is the grill symbol on a smeg oven? - Smeg SE250XUK Stainless Steel Electric Single Oven
  • 49 Answers
SOURCE: Smeg oven SA 392 EB - technical difficulties
first of all the yellow/orange light glowing is a known fault. it needs a slight wiring modification to fix it, however it dose not affect the operation of the oven nor is it dangerous.
now to the heating problem, there is a round element at the rear witch surrounds the fan. is this element getting hot? if not then it most likely needs replacing. it could be the thermostat but more likely the element.
Posted on Mar 05, 2008
SOURCE: I have a Smeg oven
Go to www.appliancesuwant.co.uk/acatalog/CookingFunctions.html
Posted on Aug 18, 2008
SOURCE: SMEG SA 398X
OK I have just moved into an apartment with this model (SA 398 X/1) and was searching for a user guide (no luck yet).
Anyhow my apartment was owned by a bachelor and it looks as though he hardly used the oven so everything's still intact.
I'm in Australia and these numbers are in Celsius so I hope they work for you.
From top Right (starting at the 2 o'clock position) the four numbers going clockwise downwards are:
50
90
120
160
Then from the left side (starting at 7 o'clock position) going clockwise upwards:
200
230
250 - with dots arching above the 250
Hope this helps -
Jane
Posted on Oct 05, 2008
  • 1462 Answers
SOURCE: meaning of symbols on oven setting.
i would know them if i were looking at it but hope this helps
line at top - top element only
line at bottom - bottom element only
line at top and bottom - conventional oven ie top and bottom elements on
wavy line - grill element
pic of fan - fan only with no heat
pic of fan with a line as well - fan oven
youi may not have all of these depending on oven.
best to use i find is fan oven - i do a lot of cooking!
Posted on Nov 05, 2008
  • 4 Answers
SOURCE: oven knobs have burn with the grill cant see the oven symbols on the oven can you help
you will need the facia panel replacing they do not have symbols
Posted on Dec 19, 2008
Help! I have a Smeg oven Model Number: SA410X-5. All of the symbols have come off. I have just moved in to a new place with this oven and have no idea what the symbols are meant to be! Im urgent need of...
here is the manual
Smeg Multi Function Built In Oven Operation Manual
specs
Description
Smeg 60cm Stainless Steel Single Oven. Model: SA410X-5
  • RRP: $1,490. The RRP is supplied by the manufacturer and is based on a brand new item, not used. It is accurate as at 1st April 2010
  • Dimensions: 595mmh x 596mmw x 567mmd
  • Smeg thermosealed, fan forced, six function, 60 minute timer
  • Capacity 66.4 litre gross, 56.1 litre net
  • Installation underbench or wall (column), fascia: flush or proud mount
  • Thermostat variable 0 -250 Celsius
  • Multifunction five cooking functions plus defrost, timer 60 minute max, variable count down timer
  • Part number: 9842 (SN:SA410X-5) (145924-2)
Spares and schematic
SMEG SA410X 5 Parts List BigWarehouse Spares
New Fascia Stickers for 15.00GBP
Smeg SA410X facia stickers for worn fronts
Apr 03, 2018 | Smeg Ovens
SMEG SC399X oven.I have accidently switched on the demo mode when leaning on the buttons. we can't turn it back on. we have tried the bell & holding down the - and + buttons
Hi,you have have probbably done this already but have you tryed unpluging it at the mains,sorry if you have already done this,all the best.
Oct 19, 2015 | Smeg Ovens
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Mar 13, 2011 | Smeg SE280X Stainless Steel Electric...
Smeg cucina SE375 single electric oven not heating-grill and lights etc working ok and fan making noise-oven approx 18 months old
Jan 14, 2011 | Smeg Ovens
Oven not working but grill is please help
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please
How to Video Tutorials on Domestic Appliances
Dec 12, 2010 | Smeg SE250XUK Stainless Steel Electric...
SMEG SA708 oven's symbols have rubbed off.
The oven symbols have rubbed off my electrolux oven. It's not even 3 years old. Please can you help?
Jul 26, 2009 | Smeg S1100MFX5 Electric Single Oven
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Meaning of symbols on oven setting.
Nov 05, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Smeg SE250XUK Stainless Steel Electric Single Oven Logo
573 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
